Wiring and PCM issues
Old Mar 30, 2015 | 11:54 AM
jeffdavee's Avatar
2006 Cobalt SS S/C with a 2.0L Ecotec.
Bear with me, it is an absolute mess.
To start off, the car was throwing multiple codes, evap sensor replaced, O2 sensor replace as well.
-Still threw codes, followed wiring harness, found numerous wires that were shorted out (not receiving ~12volts).
-Soldered and wrapped new sections of wires to PCM. Still throwing codes.
-(Something happened, father is a mechanic, he found a loose wire to nowhere, closed circuit. Car went into I believe theft mode?)
-No dash lights (Check engine light, brake light, etc.) except for the security light coming on when I turn the key on attempt to start car, nothing happens. Security light then turns off
-Looked up how to do a security relearn. Attempted that. But the security light does not remain on, which leads me to believe problem is elsewhere. Maybe the PCM?
-Changed PCM to a ZZP 1.0 PCM.
-Car will still not turn over nor start, dash lights still out, minus the security light coming on only when key is turned on, goes off after a few seconds.
-I have checked fuses have yet to find any bad ones.
I am at wits end with this car, any advice on what to do would be greatly appreciated.
Old Mar 30, 2015 | 01:19 PM
CleverOne's Avatar
double check ecu connectors are on tight and the fuse block is screwed down tight, could also have a ground loose somewhere.
Old Mar 30, 2015 | 02:14 PM
jeffdavee's Avatar
Checked both, able to bypass crank sensor and start the car, still no dash lights
Old Aug 12, 2015 | 08:48 PM
will2466's Avatar
Sorry to hijack post but I'm having similar issues. Dose any know where to buy a complete wiring harness? From PCM to all the sensors and connectors in engine.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
