wiring question
Old May 31, 2007 | 01:39 PM
widebody_balt_ss's Avatar
wiring question
ok, i have a dual voice coil sub 2+2 ohms. one ohm stable. i have the amp to match. mono 1 ohm stable. i have ran the amp bridged to the 1st voice coil, then jumped positve to positve, negitve to negitive on number 2 voice coil.... the amp goes into protect mode at about half volume.... it should be wired right for one ohm right?
help... anyone?
one view in an hour?
Last edited by widebody_balt_ss; May 31, 2007 at 01:39 PM. Reason: Automerged Doublepost
Old May 31, 2007 | 01:41 PM
cobi's Avatar
measure your sub with an ohm meter and see how much resistance is really there. 1 ohm is really low to run at and gets things hot rather quickly. Why dont you try 4 ohm?
Old May 31, 2007 | 02:26 PM
well, i just bought everything to run at one ohm... just cause i never had before. I ran it at two ohms and it sounded good. but alot louder at one ohm.
Old May 31, 2007 | 02:29 PM
Black06SSNA's Avatar
help... anyone?
Your losing me here. You have 1 2 ohm sub or 2 2 ohm subs?
Old May 31, 2007 | 02:32 PM
cobi's Avatar
try it at 4 ohm. I started out the same way running the lowest possible impedance I could but soon learned that it sounded much better the higher you went. 1 ohm is very easy to distort at, and can ruin things very fast. I ended up switching most of my stuff from 2 ohm to 4 ohm just because the loudness wasnt that much different and it sounded way better.
1 dual voice coil sub 2+2 ohms which means he can run it at 1 or 4 ohms
Old May 31, 2007 | 02:35 PM
Yea I was just making sure. What Amp is it? I have a Kicker L7 2 ohm dual voice coil and i had a JBL amp that did the same thing. Needless to say it was the damn amp.
Old May 31, 2007 | 02:37 PM
cobi's Avatar
what amp was it? most of our amps (I work for Harman=JBL/Infinity) are only 2 ohm stable.
Old May 31, 2007 | 03:41 PM
two voice coil. one sub two ohms apeice. (per v-c) the sub is one ohm stable. they are kenwood excelon brand.
Old May 31, 2007 | 06:24 PM
ptrblkz24's Avatar
Check out these diagrams:
http://www.the12volt.com/caraudio/wo...s.asp?Q=1&I=22
Old Jun 1, 2007 | 12:51 AM
EmperorJJ1's Avatar
first of all the sub doesnt care what ohm its at just worry about the amp. Now if you have a single sub and you wire it in parallel (pos to pos neg to neg) you'll get 1 ohm. If you have 2 subs you cant get one ohm with 2ohm DVC
Old Jun 1, 2007 | 12:11 PM
yeah, only one sub.
Old Jun 1, 2007 | 02:35 PM
What Amp are you using? If the highesr you turn your volume it starts going into protect mode, it sounds like your Amp can't handle it.
Old Jun 1, 2007 | 07:09 PM
yeah... thats the thing, its an 1800 watt amp, 1200 rms 1 ohm stable.... it has me confused. it should be able to handle 5 volts from the head unit. everything in my car is kenwood excelon except my 6 1/2 components.
Last edited by widebody_balt_ss; Jun 1, 2007 at 07:09 PM. Reason: Automerged Doublepost
Old Jun 1, 2007 | 08:05 PM
EmperorJJ1's Avatar
the input voltage doesnt matter... your amp isng going to go into protect because of 5v
the 2 things that id think were the problem is either a grounding issue or a ohm level issue. You stated that you have it wired to 1 ohm and your amp is 1 ohm stable it shouldnt be a problem if the amp is really 1 ohm stable. Check your grounds and make sure they are on a good chunk of metal that is clean and has no paint or anything.
also i didnt really read the first post because its confusing but now that i went over it again i just want to be sure you seeing a 1 ohm load. make sure your amp is wired like so
Old Jun 1, 2007 | 08:18 PM
Fast Freddy's Avatar
Great pic. That shows a 1 ohm load but if your bridging your amp its seeing a .5 ohm load.
Old Jun 1, 2007 | 08:26 PM
EmperorJJ1's Avatar
if its a mono amp it cant be bridged... thats what threw me off about the first post
bridging is connecting 2 channels on a amp to a single load (to act as 1 channel)
Old Jun 2, 2007 | 11:44 AM
BINGO. my amp is 2 channel but if you bridge it you can change it to mono from stereo. if i bridge it and hook it up like the pic shows and its .5 ohm. thats the problem. thank you,... I fryed the first sub,... oops. lol, oh well i have more. thanks for all the help guys.
Old Jun 2, 2007 | 04:23 PM
EmperorJJ1's Avatar
try again croutching tiger hidden dragon... the ohm load doesnt change with the amp its completely dependant on the subs BUT if you have a 2 channel amp and bridge it the ohm its stable at doubles. So your 1ohm stable 2 channel amp would become a 2 ohm stable 1 channel amp
Old Jun 3, 2007 | 12:57 PM
so dont bridge the amp run it stereo, and wire it like the diagram above?
i am just running this one to one voice coil now... its plent loud.
Last edited by widebody_balt_ss; Jun 3, 2007 at 12:57 PM. Reason: Automerged Doublepost
Old Jun 3, 2007 | 07:11 PM
EmperorJJ1's Avatar
you can do that bridged to a single coil as long as it can handle it (if you subs rated at 800rms you shouldnt give more then 400 rms to a single coil)
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
jmelton327
Sep 26, 2015 10:04 PM
