wiring a sub!!
Old Sep 6, 2007 | 11:21 PM
thedub784's Avatar
wiring a sub!!
How hard is it to wire up a sub and amp? Just a 10inch alpine type R... and an amp.
any help is appreciated!
THX!!
Old Sep 6, 2007 | 11:35 PM
tsunam1's Avatar
Just about idiot proof, just hook the power up last, everything is in the trunk with the exception of remote turn on, but just go to the local auto parts store and grab a mini fuse add-a-circuit and a 15 amp fuse, install in sunroof location of fuse panel (should have power sunroof or not). As far as how you hook up the sub depends on how much power it needs, its resistance and how many voice coils, but all that is in the instructions that come with the stuff.
Old Sep 6, 2007 | 11:38 PM
thedub784's Avatar
i'm nervous about hooking it up to the battery and which wires go where, and where do i get the wires. I'm trying to NOT spend 300 bucks for install...
ALso, i have an aftermarket HU and is that hard to hook up??
THX all
Old Sep 6, 2007 | 11:52 PM
tsunam1's Avatar
Well if you have the aftermarket head unit, that has a remote turn on lead that will turn the amp on. The power wire for the amp you can get at best buy, circuit city, or even wal-mart. I suggest at least 8 gauge wire, 4 gauge if you want to add a second amp later. You have a positive and negative on the battery and the amp, pos is red, neg is black, same for the output of the amp to the sub, so that part only has 2 colors and the remote turn on. The audio is simple cause you have the aftermarket head unit, just run RCA cables from stereo to amp, done. The head unit is easy too. if you have on-star you need the exspensive harness to keep. If not grab the malibu harness and just follow the instructions to connect it to the head unit harness, once connected, just plug it in and go.
Old Sep 6, 2007 | 11:54 PM
The Punisher's Avatar
dang tsunam1 you are just giving all kinds of advice out for the installs =) thanks for the help
Old Sep 7, 2007 | 12:00 AM
thedub784's Avatar
+rep for tsunam1 all around....
All i need is an 8 gauge power wire, RCA wires from the HU to the amp or the sub?, and some common sense...anything else??!?!?!
Old Sep 7, 2007 | 12:04 AM
tsunam1's Avatar
I just wish you guys were closer, I love wiring this stuff up! I wire up nurse call and network systems in hospitals, so I'm a wire junkie I guess
everything you get will have a wiring diagram, and everything is color coded or labeled, so common sense should about do it, lol
Old Sep 7, 2007 | 03:08 PM
BradSi's Avatar
Word!
Old Sep 8, 2007 | 01:14 PM
thedub784's Avatar
would anyone in Houston be willing to wire up my sub and amp when i get it all finished????
Old Sep 8, 2007 | 01:37 PM
BradSi's Avatar
Come to cincy n I'll do it for free ha. If you need a diagram I can make one up for you quick.
Old Sep 8, 2007 | 11:12 PM
06_cobaltSS's Avatar
Quick question, How do you hook up an amp to the stock HU?
Old Sep 9, 2007 | 02:59 PM
EmperorJJ1's Avatar
line out convertor
Old Sep 9, 2007 | 06:28 PM
where can i get it and how does it work?
Old Sep 10, 2007 | 04:03 AM
EmperorJJ1's Avatar
online, ebay, audio shop, best buy circiut city ect ect... it converts the signal from a wpeaker wire into rca for inpuy into an aftermarket amp
Old Sep 10, 2007 | 07:41 PM
tsunam1's Avatar
get the one with the gain adjustment and you can really crank it up
Old Sep 10, 2007 | 10:11 PM
O ok so the line out convertor wires up the the stock sub boxs speaker wires and has an rca plug on the other end?
Old Sep 10, 2007 | 10:54 PM
BradSi's Avatar
If i am correct in this, the line out converter splices or goes with your car speakers like rear decks? Then you plug the Rca jacks to the rca's on the amp.
Old Sep 11, 2007 | 05:26 AM
EmperorJJ1's Avatar
um yes
Old Sep 11, 2007 | 04:36 PM
o ok i know what your saying, so hook it up to the rear speakers that are in the trunk?
Old Sep 11, 2007 | 05:20 PM
BradSi's Avatar
Yup.
Old Sep 11, 2007 | 09:09 PM
cool thanks
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
dennis69
Oct 20, 2015 07:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
c_m_shooter
Sep 27, 2015 04:40 PM
jmelton327
Sep 26, 2015 10:04 PM
