wwhich o2 sensor are you wiring air/fuel ratio gauge?
Old Oct 4, 2009 | 02:04 AM
bboyfreeflow's Avatar
should i wire the air fuel ratio gauge to the o2 sensor after my cat, or the one before the cat ?
Old Oct 4, 2009 | 02:08 AM
FASTL61's Avatar
If its a shortband(gauge has 3 wires total,doesnt show numbers) its the 1st o2 before the cat and Its the purple with white stripe wire that you tap,
Old Oct 4, 2009 | 02:15 AM
yea it has a black wire(ground) red(power) a white and a Green, but i think the white wire is just to turn on the back light of the gauge....while the red powers the led lights to tell if its rich or lean etc... so sounds like i wire before the cat right ?
Old Oct 4, 2009 | 02:30 AM
FASTL61's Avatar
yup yup
Old Oct 4, 2009 | 02:38 AM
~Mike~'s Avatar
Wideband(shows digital readout)before the cat
Narrowband(sweeping led between lean,rich,stoich)after the cat
Old Oct 4, 2009 | 02:42 AM
Dead Zen's Avatar
and dont forget narrow band is weaksaus and useless, unless you like light shows
Old Oct 4, 2009 | 02:46 AM
FASTL61's Avatar
lolz.
Never heard of wiring any AF meter after the cat.Unless you like knowing how well the cats doing
Old Oct 4, 2009 | 02:47 AM
~Mike~'s Avatar
agreed...but some ppl love the pretty lights flashin around lol Kinda like a buddy of mine that put it on his 2.2 just so he could have a gauge on the pillar lol. It's a $15 autozone Faze one lol
Originally Posted by FASTL61
lolz.
Narrowbands usually work off of the first O2 sensor which is behind the cat...that's what I've always been told anyway
Old Oct 4, 2009 | 02:49 AM
FASTL61's Avatar
the 1st o2 is in front of the cat.So off the manifold or header.2nd is after the cat.
And they do serve a purpose.I put one on my car and I found out my car runs lean untill 5k RPM
Old Oct 4, 2009 | 02:51 AM
~Mike~'s Avatar
How many O2 sensors do you have? I only have one and it was most definately after my cat. I had to have the second bung welded in on the dp to hook up my wideband. Are these N/A cars different and I don't know it?
Old Oct 4, 2009 | 02:54 AM
FASTL61's Avatar
Every car 1996 and newer has atleast 2.You have a factory one on the header/DP before the cat and one after the cat.Alot of newer fords have up to 6
Old Oct 4, 2009 | 02:59 AM
~Mike~'s Avatar
I will have to slide my lazy butt up under there again, but I'm 99% there's no O2 sensor on my dp. Unless it's hiding somewhere on the header and I missed it, there isn't one. Of course, my car is a factory fluke/**** up. Mine has a stock 3" dp on it, so i dunno. It's goin to get a new muffler put on here soon and I'll check it then.
Old Oct 4, 2009 | 03:08 AM
FASTL61's Avatar
theres one there otherwise your car would run like dog ****.The computer uses the one before the cat to adjust fuel trim and the one after is to monitor the cat.
What year is your SC?
Old Oct 4, 2009 | 03:13 AM
~Mike~'s Avatar
Tis an '07...and half the time, she does run like dog ****. Oh wait...i mean THRU dogshit. My g/f decided to drive thru the yard the other day and rolled right thru a big ol pile lol
Old Oct 4, 2009 | 04:05 AM
FASTL61's Avatar
07's I believe are all on the DP.Mines an 07 and I have both on the DP.one before and one after where the cat used to be(catless).I believe the SC's are the same.Im not sure never worked on a 07 LSJ.just a couple 06's.
Old Oct 4, 2009 | 10:22 AM
if you pop the hood, and look where the downpipe is, u'll see the o2 sensor that is before the cat(s).... then look underneath the car, the other o2 is after the cat...i think all the cobalts are basically like this.... and then i think theres an o2 sensor off of the manifold itself, because they sell aftermarket ones with bungs for it, but im not sure, havent done my headers yet..
but...am i splicing the purple wire then ? with the white stripe
Old Oct 4, 2009 | 12:54 PM
FASTL61's Avatar
Correct
Old Oct 4, 2009 | 03:08 PM
hmm im only seeing a white wire, black, ....... but not purple...
Old Oct 4, 2009 | 03:34 PM
FASTL61's Avatar
Its on the car side of the harness not the o2 sensor side.Its purple with a white stripe
Old Oct 4, 2009 | 06:55 PM
k i figured it out lol thanks. i didnt get to drive it yet, cuz theres 2 cars blocking me in my driveway,so i only got to start it up and leave it at idle, and it just kept bouncing from lean to rich basically.. is that normal at idle ??
Old Oct 4, 2009 | 08:35 PM
FASTL61's Avatar
yes it will do that all the time until you floor it then it should lean over toward rich.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
DocSvensk
Sep 27, 2015 02:24 PM
jmelton327
Sep 26, 2015 10:04 PM
