Couple pictures of my progress
Pictures:
Modifications:
Engine:
Apex'i SAFC-II
Custom Cat-Back Exhaust System
Fujita Cold Air Intake
Nitrous
Pacesetter Header(made it a race header) 4-1 Header
Mobil 1 Full Syn. Engine Oil & OEM Cartridge Filter
Transmission:
B&M Short Throw Shifter
VSS Modification(remove limiter at track)
Suspension:
Eibach Sportline Lowering Springs
Interior:
A/F Ratio & Oil Pressure Gauge
Audio:
10" Sub with Amp
Pioneer 6500
Rims & Tires:
BF Goodrich g-Force T/A for drag
16" Gunmetal with Polished lip Riax Seca Series Rims wrapped in Kumho Ecsta SPT Z-Rated(215/50/16)
Security:
Alarm
Whistler 1743 Radar Detector
Nitrous setup:
Pieced together kit mostly NOS products
75 wet shot
Controlled by B&M momentary T-shifter and MSD RPM window switch with remote bottle opener
Little bugs and those kind of things I still have left:
Nitrous line from solenoid to fogger
Get SAFC-II fully installed(have to get the sensor specifications since its Hot Wire and find the rpm signal wire)
MSD RPM Window Switch(rpm signal wire needed)
Install my Eibach Sportlines
Tint windows
Tint headlights and tails
Install everything I haven't already
Drag Times:
Best RT: .521
Best 1/4: 16.005 stock 90 degrees...46% humidity
Did not have a good track day when I took my drag radials.
I am going to be in Nopi in the Chevy section. But from the looks I won't be finished which sucks.
Modifications:
Engine:
Apex'i SAFC-II
Nitrous
Transmission:
Suspension:
Interior:
Audio:
10" Sub with Amp
Pioneer 6500
Rims & Tires:
Security:
Alarm
Nitrous setup:
75 wet shot
Tint windows
Drag Times:
Best RT: .521
Nothing is fully finished...why I posted progress. I'm a little over halfway there. The pillar pod went on before Autometer released theirs. When I purchase my camber kit I will be picking the pillar up as well.
Exhaust...who cares not like anyone is going to look underneath. New exhaust going when I get the funds. Two mufflers to quiet the bish down.
Originally Posted by l Sh1ft l
looks like a shitty weld job... Not feeling the small ass rims either..
Yeah you can roll on 18s...but your going to be slow as fudge.
icc... are you going to tint your windows w/ the tint in your trunk?
I did clean my car after I took the pictures.
car looks clean but you actually should be in the mid 15's STOCK even on street tires and im thinking with your mods expecially the nitrous, intake, full exhaust im thinking mid 14's pending on what shot (35,50,75)
Originally Posted by NoleafClover
IMO i like the design of the Rims, id prefer 17", but still look good..
Originally Posted by Blackout06LS
IMO the 2.2L doesn't have enough power to pull anything above a 16" rim unless your boosted.
your 16s could weigh more then most 17"+ sizes. it just depends on the wheel weight.
Originally Posted by YellowLT
I'm running 17's and faster times than you
There is a lot that goes into the factor, and I just don't prefer big rims...what's wrong with that taste? And your looking at a time of a stock LS yet is your time stock or when you had mods?
