Nice Engine Pics..
Old May 10, 2006 | 08:13 PM
Jekyl's Avatar
Nice Engine Pics..
So I installed the Ingalls Engine Damper today... here are the results...
Old May 10, 2006 | 08:14 PM
SwizzDSMSS's Avatar
Neato... I like the Blue!
Old May 10, 2006 | 08:22 PM
Jekyl's Avatar
me too, i went blue becuase it matches my black/blue interior really well.
ninja44's Avatar
By the looks of that pic the dampner looks installed wrong. The o ring washers go in between the the dampner and the bracket.
Old May 10, 2006 | 08:23 PM
06blackg85ss's Avatar
you have the bolts backwards.... nuts are suppoesed to be against the bracket... but looks good I just did mine today
r_fiorda49's Avatar
wow that looks amazing What kind of paint did you use for the brackets and sparkplug cover? And did you have to prep them at all, ie sand 'em down?
Old May 10, 2006 | 08:24 PM
avro206's Avatar
damn you and your fancy engine paint!
j/k
My engine looks like crap. I think I need a granite blue power coated valve cover
Old May 10, 2006 | 08:30 PM
CobaltBurst's Avatar
what are you painting with? duplicolor from discount auto parts?? or what?
Old May 10, 2006 | 08:31 PM
Jekyl's Avatar
I was about to make a post and call you an idiot but..... i just double checked my instructions, and one of the pictures ( the one i happened to look at) has the nut on the wrong side lmao. And the other picture has the nut on the bracket side.
Ingalls fucked up.
Old May 10, 2006 | 08:32 PM
mi6_'s Avatar
Jekyl, that looks great! Nice and clean, not too over the top. Nice choice doing the dampner brackets too!
Old May 10, 2006 | 08:36 PM
Ingalls fucked up.
What did you paint those parts with??
Old May 10, 2006 | 08:43 PM
Nuclear's Avatar
looks great, i think i'll do mine like that
Old May 10, 2006 | 08:47 PM
Jekyl's Avatar
dupli-color anadized 2-stage paint. buy it at walmart.
Old May 10, 2006 | 08:48 PM
Jekyl's Avatar
no i didnt prep them, i just sprayed on the base coat (its sparkly) let it dry, then sprayed on the blue paint. and let it dry, it was easy and everyone thinks its anodized.
Old May 10, 2006 | 08:56 PM
Mercury's Avatar
I honestly don't think the bolts are going to change the way the brace works...
Old May 10, 2006 | 09:13 PM
Jekyl's Avatar
your right, i read through the Ingalls instructions again, and it said and I QUOTE
"The nut and bolt can be swapped with the nut against the bracket OR rod-end, but the o-ring placement should not be changed."
My o-ring is in the right spot. So i am not worried.
hacadacalopolis
Oct 28, 2015 06:09 PM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
