Forced Induction Turbos/Superchargers
2.2 plastic intake boosted
Old Sep 23, 2009 | 05:59 PM
jrocstar's Avatar
Okay I have heard that the plastic intake manifolds cannot work with the lsj as a turbo swap manifold. My questions are what is the differences with mounting? The other if the manifold can withstand -24psi vacuum without collapsing why would it be that it cannot hold over (what I am told) 12 psi of boost. It is the same pressures just opposite sides.
Old Sep 23, 2009 | 06:16 PM
blackbolt89's Avatar
if you want to boost using a plastic intake manifold you would be better off getting the 2.4 manifold. it's constructed a bit better.
Old Sep 23, 2009 | 06:29 PM
FASTL61's Avatar
the 2.2 manifold is actually a 3 peice design(not a 2 like everyone thinks) I have 2 of em sitting in my garage.The 2.4(LE5) manifold is molded as one making it along stronger.I would use that as a temp till you can get a cast mani or the sheet metal mani.Oh and they all have the exact mounting pattern
Old Sep 23, 2009 | 06:49 PM
jrocstar's Avatar
okay thanks for the info
Old Sep 23, 2009 | 06:54 PM
glen229's Avatar
zzp has 356whp on the stock 2.4 mani, ill be putting more than that threw it
Old Sep 23, 2009 | 07:37 PM
jrocstar's Avatar
you i saw you were trading your saab manifold to the 2.4 manifold. what was the reasoning for that?
Old Oct 9, 2009 | 08:16 PM
stangetr's Avatar
i have a 2.4 intake for sale if your interested, its from CED almost new- even has the adapter plate for the 2.2 throttle body
let me know
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
no_ss
Oct 18, 2015 11:58 PM
