2.2 turbo
The Garrett kit will bolt up to an Auto 2.2 and depending on the year, you may have tuning. If not you will need to run a piggyback or standalone. You also have an auto, there isnt tranny support yet.
I actually was told by my local hp tuners that they could retune my tranny to work with the garrett turbo kit(automatic)
this statement is ignorant and too widely used.
Have you tried to tune your car? Do you know how to tune your car?
Or did you get that impression from someone else?
Just because there's no standalone ecu that you can tweak doesn't mean you can't tune. Just makes the process more complex
No offense, I just think it's really ignorant when someone says something CAN'T be done
Wow, two in one night.
Okay, here is the thing with the automatic transmission on the L61 cars. The trans control modules are completely separate units from the engine controllers, but they are "married" to the engine modules. The trans controllers are slave devices. They can be flash tuned, but in this car, they have to be tuned through the engine controller. And since nobody has tuning software yet for the engine, then there is no software for the trans either. HPT does support our trans modules, but not the engines, therefor you can't get the trans module using HPT.
halfcent... is that true for the 5spds as well? im lookin to boost down the road and im gettin lots of hesitant answers about a turbo kit on my car...
speaking of which... is there a need to swap out the stock axles if i'm looking at a large hp gain?
Garrett's kit is for 2005-06 manual trans cars.
You will have axle problems if you experience uncontrolled wheel hop or hard starts from a dead stop. Just driving it on the street will be fine.
You can use a piggyback...
