Forced Induction Turbos/Superchargers
2.2L and 2.4L SC help
Old Feb 16, 2009 | 01:05 PM
stenguyen1's Avatar
Thumbs up 2.2L and 2.4L SC help
alright i will be sc my car this weekend and i have all the parts except for one piece and idk where i could find it.
wat is this part called?
this is the part:
but i wanted to use this thread so those who are sc their cars can know who to talk to for help.
so if you have sc your 2.2 or 2.4 car or going to sc your 2.2 or 2.4 car
please put your name down so we can contact you.
1. Steven stenguyen1 2.2L
2.
3.
4.
5.
6.
7.
Old Feb 16, 2009 | 02:43 PM
HunterKiller89's Avatar
theres me, beck, pk91 used to, misfitcobalt, yellowshowbalt, interviewatruins, and a few others
Old Feb 16, 2009 | 03:27 PM
rockstar014's Avatar
im going sc my 2.4 in april
Old Feb 17, 2009 | 10:24 PM
DCOBALTSS's Avatar
hi guys i would like to supercharge my 2.4 too but where can i buy a supercharger not so expensive one..
thanks
Old Feb 18, 2009 | 12:46 AM
Dragonsfire12345's Avatar
that is a good question
bump on the bracket question
Last edited by Dragonsfire12345; Feb 18, 2009 at 12:46 AM. Reason: Automerged Doublepost
Old Feb 18, 2009 | 12:48 AM
cobaltss86's Avatar
i'm going supercharged also i wonder if i need that
Old Feb 18, 2009 | 01:05 AM
yes, everyone will need the tensioner. the whole unit, not just the spring loaded part circled in blue
Old Feb 18, 2009 | 01:14 AM
mrchyzy16's Avatar
You could probably get it from Murrays, autozone or whatever parts store is in your area.
Old Feb 18, 2009 | 01:51 AM
found it!!!
part# 12584365
gmpartsdirect.com= 68.64 shipped
dealership= 93.95
found on this thread
https://www.cobaltss.net/forums/show....php?p=3224162
SUPERCHARGER PARTS LIST
PARTS LIST
Part Description Part Number
Supercharger Kit 1780003
Clamp - Fuel Pressure Regulator Hose-Intake Manifold End 10028454
Hose, Brake Booster 10358940
Nut - U-Nut Oil Level Indicator Tube Support 11507067
Nut - U-Nut Radiator Hose Support 11507067
Clamp - Coolant Hose Cap 11516226
Bolt/Screw - Intake Manifold Bracket-to-Engine Block 11516342
Bolt/Screw - Intake Manifold Bracket-to-Intake Manifold 11516506
Nut - Intake Manifold 11516076
Bolt/Screw - Radiator Hose Support 11516757
Bolt/Screw - Drive Belt Idler Pulley Bracket 11518048
Bolt/Screw - Generator Relocation Bracket 11518051
Bolt/Screw - Intake Manifold 11518062
Nut - Intake Manifold-to-Head 11518532
Bolt/Screw - Generator Relocation Bracket 11589134
Bolt/Screw - Drive Belt Tensioner 11589147
Bolt/Screw - S/C TO Intake Manifold 11589214
Bolt/Screw - Oil Level Indicator Tube 11589299
Bolt/Screw - Drive Belt Tensioner 11589312
Pin, Connector – Female 12048074
Connector Pin Seals 12048087
Lock-Connector - IAC Connector 12052634
IAT Connector Replacement 12052641
Map Connector Replacement 12110293
Zip Tie 12355066
Connector - PCV Tube 12581198
Tensioner Assembly - Drive Belt 12583180
Supercharger Assembly 12584331
Vacuum Hose - Fuel Pressure Regulator 12584337
Gasket - Supercharger Outlet 12584342
Manifold Assembly – Intake 12584348
Gasket - Intake Manifold 12584359
Bracket Assembly - Drive Belt Idler Pulley 12584364
Bracket - Generator Relocation 12584365
Tube Assembly - Intake Manifold-to-Fuel Regulator (LSJ Purge Valve Hose) 12584369
Brace - Intake Manifold 12586632
n GM SPORT COMPACT Performance Build Book 39
PARTS LIST
Adapter - Throttle Body 12590814
Belt - Accessory Drive 12590815
Wire Assembly - Map Sensor 12590818
Data File – PCM Engine Calibration 12590819
Data File - PCM Engine Calibration 12590820
Stud - Intake Manifold 12590821
Stud - Intake Manifold 12590822
Bolt/Screw - Throttle Body Adapter (M6 X 20 mm Socket Head Cap Screw) 12593676
Washer - 17 mm OD For a M8 Bolt x 4 mm Thick 12593677
Sticker, Carb E/O 12593900
Template - Intake Manifold Gasket Cut Out 12593902
Instruction Cd 12593903
Injector Assembly – Fuel 12593904
Plug, Map Sensor 12593906
Gasket - Throttle Body Adapter Plate (O-Ring) 12593905
Template - Dip Stick Tube Support Bracket 12593907
Support - Radiator Hose 12594613
Cap Assembly - Cool Hose 15544596
Cable Assembly - Cruise Control 22688111
Hose Assembly - Radiator Inlet 22718761
Vacuum Fitting - Waste Gate 24507839
Air Duct 24575436
Premium Fuel Decal 25602518
Last edited by Dragonsfire12345; Feb 18, 2009 at 01:55 AM. Reason: Automerged Doublepost
Old Feb 18, 2009 | 02:03 AM
cobaltss86's Avatar
nice good job i think i'm gonna go to the dealership so i can have it in time tho
Old Feb 18, 2009 | 02:05 AM
also your gonna need m8 1.25x 120mm bolts x2 and another but 130mm
and I'm gonna need more money rofl
Old Feb 18, 2009 | 02:14 AM
scottyguy401's Avatar
I'm going supercharged
What are those bolts for? The bracket for the idler pulley/tensioner, or is it for the alternator?
Old Feb 18, 2009 | 02:20 AM
cobaltss86's Avatar
man i feel you on money
there for the bracket i'm thinking
Last edited by cobaltss86; Feb 18, 2009 at 02:20 AM. Reason: Automerged Doublepost
Old Feb 18, 2009 | 03:27 AM
both. On the stock cars, the bolts are 100mm and go through the alternator and bolt in to the block. you need 120mm bolts because they will now go through the alternator, then the bracket, then the block. the bracket adds an extra 25mm of length, but 20mm is enough to get the job done, as 130mm bolts would stick out a little
Old Feb 18, 2009 | 03:34 AM
Alright cool, thanks for clearing that up. That makes me feel a lot better, I thought I was gonna have to get more new bolts to make things fit lol.
Old Feb 18, 2009 | 08:28 AM
stenguyen1's Avatar
thanks for lookin that up for me. i found someone on here to sell me the bracket only. cuz 65 bucks was alot for that bracket. now that i have all the parts i will start breakin my car down on friday.
Old Feb 18, 2009 | 08:43 AM
just ordered it from gmpartsdirect.... I hope it comes in soon!!!
Old May 12, 2009 | 07:47 PM
RobHole's Avatar
holy **** am I happy to have discovered this thread thanks to FF22 on bcj .
I was looking for that bracket part #!!!
GaryGibblez
Jan 14, 2020 10:35 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
ThoR294
Oct 4, 2015 08:44 PM
jmelton327
Sep 25, 2015 09:44 AM
