2.2L Turbo Advantages
Just wondering which engine would have more an advantage of a turbo. Now we all know the 2.4L will produce more, but which is more turbo friendly? I can not think of the term right now...I mean the part...but responds better? I believes its the throws...or the throttle body....
Oh anyone know if SEMA (by Philly) this April will have turbos for the Cobalt? Thanks!
alright, yea cuz im lookin into the mazda3 and the 2.0L engine has better ratios for the turbo than the 2.3L...but of course the 2.3L produces more...got the 2.0L up to 350whp, and 2.3L up to 500whp
Well, the things is with a bigger 4 cylinder engine like the 2.4ss, there might be a possible reliability issue because the 2.4 has a bigger bore than say a 2.2 or 2.0 from the cobalt, so because of this, the cylinder walls are thinner thus not as efficient as taking heat out as a car with a bigger cylinder wall. In a 4 cylinder application, the bigger the displacement usually the harder it is on the rods so if you were boost a 2.4, you'd prolly need to internals to accomidate boost levels higher than say 6-8lbs id say.
2.4's have forged rods. 2.4 is definatly a more advanced engine. With a good tune, the 2.4 can handle 8psi all day long, with higher octane gas, you could see as high as 12-14. Both will need internal work once gone past the 300 mark.
Originally Posted by roccityroller
Bingo, hence why honda's s2000's 2.0L makes 240hp and my 2.2 only makes 145.
Dont mistake that for better enginerring .... just enginered with a different purpose in mind
The 2.4 will make more power if the compression ratio is low enough to allow high boost levels and the rods and crank and pistons are all forged pieces. However it would be interesting to spend time on the Dyno at a cam grinding company. the VVT valvetrain could create a situation where you might not make optimal power at all rpm levels. Generally turbos do not like a lot of overlap between the intake and exhaust valves closing. (Flames and Backfiring in the exhaust) a lot of unburned fuel. If I were turboing a VVT ecotec I would be calling some of the big Cam companies to see if they have done any R&D on these motors with a turbo. This is new ground to cover.If Comp Cams, and Crane, and Edelbrock get enough requests they will develop some performance cams for the VVT Ecotec. anyways because it's bigger than the Honda motors it should waste em'.
I could be wrong but I think that VVT turbo cams could be the answer to getting rid of that little bit of lag that even ball bearing turbos have. they could be designed to bring on the power at a more even rate instead of being kicked in the rear the application of power might come on smoother.This thought also comes to mind, staging a low boost turbo for around town and a high output turbo for the track. It seems to me that VVT could make that work really well. What do Ya'll think about that?
Obviously from 2.0L to 2.2L to 2.4L is the order of which would be most turbo friendly for compression reasons. Yet because of the increased compression you can make more power on less boost, you just can't run as much boost which may cancel out any advantage on that part. However, as said before there is no replacement for displacement, I'd put my money on the 2.4L. Especially if you bring in built bottom ends to the equation...
how would the 2.2... or 2.4 for that matter be the best for turboing?? GM usues a 2.0 to drag race with... and over 1,000hp, tuens it into a 2.2 for a lil more power. Id put my bet on the 2.0 being the best motor to turbo, which is Y i'm buyin the SS S/C, so i can turbo it down the line.
Well then if you had a 2. and a 2.2 you could do they same things and the 2.2 would make more power...so it is displacement.
hate to break it to everyone but the vvt used on the 2.4 does NOT increase power, it is responsible for the improved fuel economy. a version of vvt like the one used on hondas and ferraris would provide more power. the reason for the extra power in the 2.4 versus the 2.2 is displacement and not vvt.
due to the higher compression ratio on the 2.4l, a turbocharger providing the same boost would offer a greater % increase in power. if adjusted to the same compression and displacement, the 2.2 would be fairly equivelant to the 2.4 in power, but would offer fuel economy benefits.
