Forced Induction Turbos/Superchargers
2.2L Turbo Advantages
Old Mar 30, 2006 | 05:02 AM
NJHK's Avatar
Originally Posted by roccityroller
Bingo, hence why honda's s2000's 2.0L makes 240hp and my 2.2 only makes 145.
Engineering, yes but well balanced powerband, no. Hondas are notorious for making high horsepower due to:
1. High Revving
2. Variable Valve Timing
3. Higher CFM flowing cylinder heads
but because of these things, their power is only made in higher RPMs and have terrible amounts of torque. The only reason the S2000 is fast is because it's a light vehicle and it's a little more well balanced power wise, closer ratio'd gearing and higher powered as far as power goes than their other motors (168 lbs of torque).
Originally Posted by IonNinja
stock for stock the only reason the 2.0 would be better is because of its bottom end (which is NOT forged btw, just learned that recently) which will allow you to throw more boost at it. My guess is that a stock bottom end 2.2 or 2.4 would make similar numbers to a stock SS/SC but with more TQ. With all having built bottoms ends though I'd put my money on the car with the most displacement.
When you say forged, you have to realize that there are different degrees and levels. People see forged and associate it with HIGH quality forged products like Wiseco Pistons make or Eagle Rods. If you want to get technical, every piston and rod is forged because it's the process to strengthen them...but of course...to a degree.
Originally Posted by RuSSo-29
how would the 2.2... or 2.4 for that matter be the best for turboing?? GM usues a 2.0 to drag race with... and over 1,000hp, tuens it into a 2.2 for a lil more power. Id put my bet on the 2.0 being the best motor to turbo, which is Y i'm buyin the SS S/C, so i can turbo it down the line.
You know why GM makes over 1,000 HP with the 2.0 motor rather than the 2.2? Less stroke = More reliable higher revving. You think they rev up to 6,000 RPMs like us? No way...
Also, GM puts out the 2.0 ECOTEC to be boosted because more so the compression issue and fuel octane, they don't want detonation to be an issue. I'm not 100% sure but I believe you can run 89 octane on the 2.0 S/C ECOTECs which might sound reasonable for the average person who doesn't want to spend high amounts of money on fuel everytime they have to filler-up.
Originally Posted by Ecophyte
I could be wrong but I think that VVT turbo cams could be the answer to getting rid of that little bit of lag that even ball bearing turbos have. they could be designed to bring on the power at a more even rate instead of being kicked in the rear the application of power might come on smoother.This thought also comes to mind, staging a low boost turbo for around town and a high output turbo for the track. It seems to me that VVT could make that work really well. What do Ya'll think about that?
Umm what?
Sorry, I'm not trying to flame you but you need to read up more on turbos and turbo lag. Have you ever personally been in a vehicle with ball bearing turbo? Those suckers are like instant FULL boost because they spin so fast and easily. People associate turbo lag with every turbo'd vehicle, which is not the case most of the time. If you match a turbo properly to a motor, you will not have turbo lag. Also, turbo lag is something that is more so split second if it happends.
By the way guys, did you know there is a such thing as supercharger lag? yes...it happends.
As far as "low boost around town and a high output turbo for the track", once again, you should read how turbocharged systems work. If someone wants to run low amounts of boost, they should get a wastegate spring that is more limited (for example, I have a 68 MM wastegate that has a 5 PSI wastegate spring). If I say want to run over 5 PSI for track reasons or racing reasons, that's what a boost controller is for. The boost controller will not (and can not) decrease your max psi lower than your wastegate.
Originally Posted by CivicKiller98
hate to break it to everyone but the vvt used on the 2.4 does NOT increase power, it is responsible for the improved fuel economy. a version of vvt like the one used on hondas and ferraris would provide more power. the reason for the extra power in the 2.4 versus the 2.2 is displacement and not vvt.
I wouldn't say that 100% will not increase power. I've always said that Variable Valve Timing is only as good as you can manipulate it. Look at guys with V-tec, they have V-tec controllers to change the lift and all that good stuff to make great power gains from that. Just something to think about...
Originally Posted by celicacobalt
i saw somewhere that cylinder walls being big making the engine stronger and less heat was actually proved wrong
You mean thicker cylinder walls, not "bigger".
Well, the things is with a bigger 4 cylinder engine like the 2.4ss, there might be a possible reliability issue because the 2.4 has a bigger bore than say a 2.2 or 2.0 from the cobalt, so because of this, the cylinder walls are thinner thus not as efficient as taking heat out as a car with a bigger cylinder wall. In a 4 cylinder application, the bigger the displacement usually the harder it is on the rods so if you were boost a 2.4, you'd prolly need to internals to accomidate boost levels higher than say 6-8lbs id say.
There should enough "meat" on the 2.4 cylinder walls to handle boost.
In conclusion, I will say this...
You CAN boost a 2.4 motor. The issues are not compression but detonation. If you can find a way to retard timing, that will lead to a better running turbocharged vehicle, even on 10.5:1 compression. If you don't change the timing, you'll be pushing the limits while boosted and depending on what PSI you choose to run, fuel octane will be an issue. Remember, higher octane and retarding timing is for reducing detonation....compression doesn't matter (well in our cases, it wouldn't matter).
I've talked enough.
Old Mar 31, 2006 | 02:06 AM
CivicKiller98's Avatar
ok i dont mean to be rude, but i think you had better read up on gm's vvt. its sole purpose is to optimize fuel economy. it allows advancement and retarding camshaft timing and the algorithm in the E67 was programmed solely around increasing fuel economy using closed loop feedback. tuning for power is independant from the vvt system. if anything, it is more of a burden than a gain for power.
the honda vtec incorporates a second lobe at a specified rpm, which is why it can provide more power.
even better, the 'vvt' used on some european cars has a better system. again more power because of adjusting the effective part of the cam.
dodge/chrysler vvt is one that i have yet to read up on, but i am sure that it is a varation on one of the above.
Old Mar 31, 2006 | 02:12 AM
NJHK's Avatar
Isn't the VVT in the 2.4 motor based off of Toyotas VVT-i technology?
Old Mar 31, 2006 | 03:18 AM
i dunno about that, but its the same principle. are you confused with toyota's VVTL-i technology?
Old Mar 31, 2006 | 03:48 AM
NJHK's Avatar
Possibly. You probably know more about it than I do though. I'm kind of limited in information when it comes to VVT.
Old Mar 31, 2006 | 12:08 PM
Brandon97Z's Avatar
I was under the impression that the vvt in the 2.4 also helps keep the tq from droping off in the middle to upper rpms. On stock dyno's you can see the little hump where they start changing.
Old Mar 31, 2006 | 12:18 PM
Brandon97Z's Avatar
Look there about 3800 or so on the stock tq graph
Old Mar 31, 2006 | 12:21 PM
Brandon97Z's Avatar
and tuning the 2.4 is no problem. Companies have already broken the ecu and already have turbo tuned calibrations.
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
maliki778
Oct 1, 2015 07:39 PM
