20g Feed/Return
20g Feed/Return
Okay I've searched all over and yet to find a real answer. For those of you running the 20g what is the size of the oil feed oil return and water banjo bolts ? did you use stock lines with different bolts ? make lines ? I happened across one and will be putting it all together shortly
Thanks in advance
-Brad
Thanks in advance
-Brad
The one on the thermostat housing is 1/2npt
The one on the front of the head with the barbed bolt going through it is m14x1.5mm
I used this for my oil drain and bought the -10an block fitting from treadstone. Bolt spacing on the 20g is 38mm and standard is 40 or 50.
http://pages.ebay.com/link/?nav=item...d=301940140863
-10AN for the oil drain
-6AN for the coolant feed & return
Like, the Saturn S-series? Just dont!
No.
I bought the fittings individually.
You need a 1/2NPT to 6an. This goes on the t stat housing.
You need a m14x1.5 to 6an banjo fitting. This goes on the front of the head. You will only use the banjo and not the bolt. You use the stock bolt that goes to the coolant tank still.
Deathshead
May 22, 2016 12:27 PM
