Air Bypass Valve
Air Bypass Valve
I know almost everyone want to get and has been thinking of getting a CAI of you don't aready have one. as is the case with most SS owners. but I have not herd anyone tlak about the air Bypass vavle to protect the engine from water that can be sucked up the intake.
I'm looking at all these one peace systems, and i don't know where I should put this.
I'm really afraid of the intake sucking back water, then boom your engine is finished.
it only takes you to drive through one good sized puddle, during or after a heavy rain fall.
any takes on this?
any takes on this?
Yah I saw the AEM one, I'm thingking this is something I should get, but if you put it before the SC it's already to late. and Behind the Filter! i don't know if it will do anything at that point
I guess with the bypass if water starts to be sucked up from the filter it shuts down and starts drawing the air from the bypass.... there are 2 pieces for the intake tube.. from the SC to the driver side headlight and from there down into the driver side wheel well behind the fog light... why couldn't you just put it between the 2 intake tube pieces
I know that our current intake is two peace. I have no problem with that, because there is the air box to protect the current filter.
but if i get the CAI there is no stopping the water
True... from the looks of the K&N it looked all 1 piece
No need to worry Eddie, I had a AEM CAI on my Z24 and drove through some pretty big puddles. I wouldn't worry unless we had a flood like the last and the filter is TOTALLY submerged and you start revving the engine.
The air box is surrounded by wheel shroud so unless your going to drive through a giant ass puddle I would say the chances of water getting into any CAI (at least where it's located from the factory) is small.
I would assume they would be the same length as the factory.. If it was any longer we would have to take the shroud off and then worry about banging it if we drive up driveways or whatever. Our cars are real low to the ground from the factory I didn't realize how low they were when I started driving around in it. We could possibly take out our driver side fog light and have a tiny ram air duct
I noticed AEM had different size bypass valves like 2.25, 2.5, 2.75, and 3.0.. I was wandering if anyone knew the difference in the sizes and if a certain size would restrict air or something from the CAI.. I just didnt know why there are different sizes thankss
Right. People are way too sensitive about this in general, IMO. Splashing an inconsequental amount of water on a filter isn't going to hydrolock you, let alone as how Zinner states its in a protected position. I mentioned this to Teske@Gravana awhile before I pre-ordered my intake, he agreed NO problem with their location, and I'll be driving in the winter as well.
So, don't worry about it unless you live in New Orleans.
oooh. that was bad.
OrangeCoba
Sep 25, 2015 06:06 PM
