Forced Induction Turbos/Superchargers
which is better????
Old Apr 1, 2008 | 11:39 PM
LS_RIDA28's Avatar
which is better????
hey guys i was just wondering which one would be better a procharger or a turbocharger??
Old Apr 1, 2008 | 11:40 PM
Altiery54's Avatar
turbo
Old Apr 1, 2008 | 11:42 PM
XM15's Avatar
Turbo. But there are so many variables that its not that simple.
For you though: turbo.
Old Apr 1, 2008 | 11:43 PM
LS_RIDA28's Avatar
which is better in the long run maintance performance and engine wise??
Old Apr 1, 2008 | 11:45 PM
cobalt_driver's Avatar
depends. each have different specs. a turbo is for more top end n mid range power. a procharger is both turbod n supercharged. a supercharger is for instant boost. when u have a procharger u have both low end boost n top end boost. idk, depends on how much serious power YOU want. lol.
Old Apr 1, 2008 | 11:49 PM
XM15's Avatar
A centrifugal supercharger will give you almost no low end and will build boost all the way up to redline. Its not the most ideal setup for a low-torque 4-banger, but to each his own.
Kind of confusing.
A centrifugal supercharger is belt driven, hence why it is a supercharger. The compressor however is not like the roots style lobes, but like a turbo compressor. The centrifugal supercharger hits peak boost at redline, no matter what the application. Where a turbo hits peak boost depends on the size of the turbocharger and the engine its on.
Old Apr 1, 2008 | 11:52 PM
LS_RIDA28's Avatar
I am very very serious about power through any range i really need it
BAD lol
Old Apr 1, 2008 | 11:55 PM
Kind of confusing.
correct but since its belt driven, theres no real "lag" n as soon as u punch it, u should generate boost. diff than a turbo. also correct with the compressor. but, guys who r like dead set on insane numbers really mess with the compressor.
the best thing to do is to look things up and research for urself. ur on the right track though with asking questions.
but lemme ask you, what are ur power goals? what do u want to achieve power wise? after u establish a power goal u can roll from there and pick n choose some options.
Old Apr 2, 2008 | 12:03 AM
LS_RIDA28's Avatar
i'm looking to get into the 200's maybe like 230-250 whp i need it cuz i cruz with a car club and lately theres been alot of cars that have been coming out and teams are starting to call out other teams and i want to contribute you know
Old Apr 2, 2008 | 12:10 AM
Greased's Avatar
dude, get a turbo, end of story.
/thread
Old Apr 2, 2008 | 12:25 AM
LS_RIDA28's Avatar
gottcha oh by the way do you think the garrett turbo can make the horsepower i want?? or do i have to mix and match a turbonetics kit??
Old Apr 2, 2008 | 03:33 PM
XM15's Avatar
With their stock tune and at 8psi you should make about 200whp, maybe a little more. If you go with some other tuning, that turbo is more than capable of giving you 250whp. I don't know how long your internals will be good for though if you are making that much power.
Technically, yes there is no lag. But you are making pretty low boost. Just because a turbo has to spool up, doesn't mean that its not making boost at low rpms. Depending on the turbo you are using, the lag isn't that bad. Look at the SS/SC. It has 260 tq at 2500 rpms. Its really just about preference. If you have a particular power goal, you can find a way to get their using either way.
Old Apr 2, 2008 | 06:19 PM
mike25's Avatar
now adays with dual scroll turbos and properly sized on your application there is minimal lag, if any. build her right and youl have power like a supercharger....still though youl always generate more top end with the turbo
Old Apr 2, 2008 | 06:39 PM
FacelessKhaos's Avatar
i'm actually going with a smaller turbo myself...it will start spooling almost when you turn the key...but will generate boost around the 2k mark dropping off at around the 5k mark making it fast and reliable.... so for you i would think a decent size turbo with a spool that is quick but depending on the CFM rate that will ultimately determine how much boost you should run...whether it be 8 psi or 11psi etc. so research those flow charts on both the centrifugal superchargers and the turbos and make a decision based on that....
Old Apr 3, 2008 | 08:59 PM
brandon2.2's Avatar
I think a good turbo kit will be cheaper for you. a good garrett kit is like $2800 and you get what you need to slap her on and enjoy. But if you want a procharger kit from like Speed mafia performance, its $2800 for there lowest kit w/out an intercooler. you will have better luck with the turbo.
and you know what. I dont really like turbos, I am a really big fan of Prochargers (the product and the company) so it is an un-biased opinion there buddy
Old Apr 5, 2008 | 03:48 PM
LS_RIDA28's Avatar
ok but i thought the garrett turbo costs 3699 not 2800 i want the alpha kit not there basic one
Old Apr 7, 2008 | 06:11 PM
LS_RIDA28's Avatar
hey i was just wondering if i get the DC SPORTS cat-back and with the DC SPORTS headers can i procharge it and still keep the headers???
Old Apr 7, 2008 | 07:29 PM
mike25's Avatar
yep..
Old Apr 7, 2008 | 07:41 PM
INDColtsFan18's Avatar
def get a turbo, with your current mods + a turbo you'll be 200+ HP and be able to beat those stock SS/SC's flying around.
Old Apr 8, 2008 | 10:24 AM
LS_RIDA28's Avatar
alright will do
