Forced Induction Turbos/Superchargers
boost problems help please
Old Dec 11, 2013 | 03:17 PM
jdog1990's Avatar
Originally Posted by ECaulk
Vacuum lines connected correctly? Air filter not covered in an excess of crap?
they should be connected correctly. and the air filter is new but on top of the air box is a metal plate over top of the hole of the air box with very little room for air to get in could that be a problem?
Old Dec 11, 2013 | 03:20 PM
Not sure, you could do the airbox mod for more airflow and sound
Old Dec 11, 2013 | 03:24 PM
jdog1990's Avatar
or do you think its not that simple of a thing if i give it more air that it would fix it or you think its a bypass valve or solenoid
Old Dec 11, 2013 | 03:34 PM
yellowsupercharged06's Avatar
could be your bypass, could be a cracked line .... would love to see wat the AFR is on this bad boy lol
Old Dec 11, 2013 | 03:45 PM
Shanedude's Avatar
I'm not familiar with lsj's but what is this metal plate restricting air...Does it look like a walmart mod or OEM stock?
Old Dec 12, 2013 | 07:49 AM
joshcsepegi's Avatar
Sounds like your setting knock or high ait so it's pulling timing.
Your boost valve could be bad.
Old Dec 12, 2013 | 09:29 AM
jdog1990's Avatar
the metal plate was restricting the air flow and its OEM stock part it only had about an 1/8th of an inch gap for the air to get in so I took that metal plate off and it boosts 12psi now.
Old Dec 12, 2013 | 09:37 AM
WTF are you talking about ?
Im going to LMFAO if you took your TB apart lol
Old Dec 12, 2013 | 09:38 AM
Sounds like something wasn't install correctly, a stock part shouldn't restrict airflow that much. Any pics of the piece and location?
Old Dec 12, 2013 | 09:55 AM
blueLNFftw's Avatar
bahahahaha
Old Dec 12, 2013 | 09:59 AM
  #36
jdog1990's Avatar
no it has nothing to do with the tb it was down in the bumper where the stock air box is and on top of the oval opening a metal plate was on top of that opening and restricting flow. Name:  newpics030.jpg
Old Dec 12, 2013 | 10:04 AM
  #37
blueLNFftw's Avatar
So you cut out your maf sensor?
Old Dec 12, 2013 | 10:07 AM
  #38
soo im assuming someone put a metal plate over it to keep water from getting in lmao ... wata moron.
by oval you mean the 4 sided opening all the way to the left of the picture, where the air is sucked in ?
Old Dec 12, 2013 | 10:16 AM
  #39
jdog1990's Avatar
no I took the metal part off for the air box opening the oval opening. yes yellow but it wasn't attached to the air box it was screwed to the head light mount hovering over the opening and I took it off and now the car works properly
Old Dec 12, 2013 | 10:20 AM
  #40
blueLNFftw's Avatar
Picture of it?
Old Dec 12, 2013 | 10:29 AM
  #41
Sounds like some mount from a previous intake
Old Dec 12, 2013 | 10:34 AM
  #42
no our intakes are hydrolock heaven, it was most likely on there to prevent water from entering the intake.
not that the stock intake has that issue though. The aftermarket intakes are more prone to sucking in some water if a hydro shield is not installed.
but glad you figured it out, now get a zzp 3 incher
Old Dec 12, 2013 | 10:45 AM
  #43
I kinda figured it was aftermarket, I do know its a huge problem with the lsj's someone local to me got really really lucky when he sucked up some water in his lsj.
Old Dec 12, 2013 | 10:51 AM
  #44
jdog1990's Avatar
Picture of it?
Old Dec 12, 2013 | 10:53 AM
  #45
blueLNFftw's Avatar
Old Dec 12, 2013 | 10:55 AM
  #46
blueLNFftw's Avatar
idk what the **** that think is lol
Old Dec 12, 2013 | 10:57 AM
  #47
jdog1990's Avatar
I don't know either no one else has or had that part on top of the oval opening of the airbox?
Old Dec 12, 2013 | 10:58 AM
  #48
blueLNFftw's Avatar
nope. and based on the craftsmanship, some one made that lol
Old Dec 12, 2013 | 11:00 AM
  #49
That looks like ghetto ass home made I don't want my kid beating the **** out of the car so I'll restrict the intake
  #50
haahahaha looks like a mini frying pan lmao ... prbly weighted 5lbs lol
hahaha poor car ... getting horse **** fuel trims and AFR
