Borg Warner 257
Borg Warner 257
OK guys as some of you know this week I am tuning a 257 .63ar on 100% stock engine running E47. I'm expecting the stock fuel system to be able to keep up on spool but not topend on high boost but we'll see what I can get from it.
So if you haven't heard anything about the 257 here's some info
Compressor Specifications
◾Compressor Type: Forged-Milled Wheel (FMW) Extended Tip
◾Compressor Wheel OD (exducer): 76mm
◾Compressor Wheel Inducer: 57.2mm
◾Max Flow Rate: 64 lb/min
◾Compressor Housing Connections:
◾Inlet: 4.0" Hose Coupler
◾Outlet: 2.0" Hose Coupler
Turbine Specifications
◾Turbine Type: High Efficiency S200SX Inconel Turbine Wheel
◾Turbine Wheel OD: 70mm
Lots more to come after I get the trims dialed in I will post my first impressions but get ready for lot of info and updates as we get the tuning done
Just an update for everybody my car is currently getting the throw out bearing replaced again the new one that I received was faulty for manufacture so I should have the car ready to tune on Monday evening and a dyno run shortly after the tune is completed
Oh shoot I forgot to close that thread sorry man. Yeah I got it figured out it was the two wires heading to the fuse box in the engine I got one on but not the other.
And thanks for the gl km0 and I keep talking back and forth of what we are going to do to this car. And I think the official conclusion is after this is all tuned out I'll do a full engine build (block,4340 rods, wiseco pistons, ported heads, stage 2 cams,and 82# springs.) Then I'll be satisfied haha.
