Forced Induction Turbos/Superchargers
BOV problem
Old Sep 4, 2010 | 02:18 PM
turbohornet88's Avatar
BOV problem
I just installed a hks bov and dejon charge pipes with the MAS reloction flange. put it all on, adjusted my vacuum hoses to skuruc's dejon piping install thread. My problem is i boost a couple times normal and then it only starts boosting 3 psi. I am not tuned. thinking about getting one. I also dont have a block off plate. Help me out please.
Old Sep 4, 2010 | 02:42 PM
TommyP's Avatar
AWD > FWD
You did a MAF relocate without a tune?
Old Sep 4, 2010 | 06:25 PM
09CobaltSS1's Avatar
Either go back to your stock charge pipe, or get a tune immediately! You can not relocate the MAF without tunning for it.
Old Sep 4, 2010 | 06:47 PM
O9cobaltSS's Avatar
does this mean i cant do my dejon cp w hks bov either? (planning on tuning after i do the cp n dp) i was planning on it soon... :/ this only happend bc he relocated the mas correct??? hhmmmmm might just get my synapse dp first..
Old Sep 4, 2010 | 06:58 PM
i moved around a couple vacuum hoses and it runs fine and boosts normal now.
Old Sep 4, 2010 | 07:04 PM
TommyP's Avatar
AWD > FWD
Ya but you should see your fuel trims. You wanna know what really wrong go get an interceptor
Old Sep 4, 2010 | 11:08 PM
the problem came back. its still acting up.
Old Sep 12, 2010 | 05:01 PM
BlackCobalt707's Avatar
tune it and your problem might be fixed
Old Sep 28, 2010 | 06:26 PM
maddmojo15's Avatar
i have a 2010 cobalt ss t/c. i replaced the factory charge pipe w/ the dejon charge pipe kit w/ the hks bov. since then at random times, vehicle only puts out 3-4 psi... does anybody know what may cause this? if so... what do u suggest. thanks
Old Sep 30, 2010 | 12:53 PM
chudson91's Avatar
yea its because you are blowing off metered air out the window.lol i started off that same way when i didnt no much but either get a tune and fix the maf or relocated and tune like most are doing when they run bov. until then if you still want to have the hks, t the hks into the top of the intake manifold and leave the stock bpv hooked up the same way. now you have two.
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
