Forced Induction Turbos/Superchargers
Eaton n00b question...
Old Jun 19, 2009 | 06:17 PM
Sarra's Avatar
Been reading up about blowers, and just want to make sure that I have this correct.
So, if you had two identical engines, let's use the LSJ for example, and had two identical superchargers on them, M62's (keeping it simple), they would obviously have identical boost characteristics.
Lets get hypothetical. Leave one stock, and bore out the intake, port the heads, put larger valves in the heads, cams, add something crazy like the BMW variable valve control system used in the non USDM 770 (the 770 had no throttle body, the cam position, duration, and lift could be varied SO MUCH and so quickly, that it could be used as throttle control and idle control), and put in a larger diameter exhaust on one. This is theoretical, so we're talking about an almost unstreetable setup, this thing would NOT idle worth a crap (well, the BMW 770 style valve trickery might change that).
The question would be, would this variation in the overall geometry of the way the engine can breathe effect the amount of actual boost you would see in the intake manifold? Or am I understanding how this works wrong, and it has more to do with the cylinder fills up, then the air backs up into the lower intake, and that is where your boost comes from with a blower?
Old Jun 19, 2009 | 06:26 PM
the_rainmaker's Avatar
i think that none of that would make a difference as the supercharger itself creates the boost not the supporting mods.
you not actually doing anything to make the blower push more air into the cylender....
I could be wrong... I dont really know **** lol
Old Jun 19, 2009 | 06:32 PM
Sarra's Avatar
Centrifugal superchargers compress air. Blowers blow air, and don't compress it internally.
Old Jun 19, 2009 | 07:28 PM
HunterKiller89's Avatar
you would see less boost. With those mods, VE would increase, leaving less air in the intake manifold, reducing the amount of boost pressure.
Old Jun 19, 2009 | 09:21 PM
Sarra's Avatar
That is what I thought, thanks. Now time to start doing research...
Turbo Johnny
Feb 21, 2019 09:41 AM
Turbo6
Aug 27, 2015 08:37 PM
adam0416
Jul 20, 2006 03:55 AM
JonyyB
May 26, 2006 04:57 AM
forsberg2110
Nov 25, 2004 02:15 AM
