Forced Induction Turbos/Superchargers
Fc3s/fd3s Turbo?
Old Apr 19, 2010 | 07:17 PM
terry11's Avatar
Fc3s/fd3s Turbo?
I found a really good deal on a brand new fc3s/fd3s turbo. It's a 60 trim and was designed for rx-7's and mitsubishi 4 and 6 cylinder motors. Standard t4 flange and it says 60 a/r on the housing but on the exhaust housing it says A/R 1.15 That's not 115 mm is it? It would be absolutely huge if that was the case.
This is what it says on one web site "It is a perfect fit to the Mazda rotary motors. Larger Toyota, Honda, Mitsubishi, 4 and 6 cylinders seeking 475HP+ with very fast spool. This combination of AR (Hot/Cold) results in a quick spooling turbo for the Mazda motors."
Inlet (exducer/hot side) T-4 Flange 70.1mm x 82.55mm (2.76” x3.25”)
Outlet (exducer/hot side) Sized for press fit or weld in V-Band adaptor
Inlet (compressor/cold side) Ø 76mm (3”)
Outlet (compressor/cold side) Ø 52mm (2”)
Exducer A/R 1.15 (sized for Mazda rotary motors)
Compressor Style 0.60
Bearing Type plain
The turbo I have right now is .70 a/r and doesnt spool... like ever lol Will this work better for me? I'm still kicking around the twin charge deal but might just run this turbo if it will work better for me
Old Apr 19, 2010 | 08:52 PM
07cobaltguy's Avatar
1.15 a/r will spool later than a 0.60 a/r housing.
Old Apr 20, 2010 | 03:22 PM
terry11's Avatar
The turbo i'm running now is 70 a/r...
Could I get a different hot side housing for it and just swap them out?
I don't know if I can tho with this turbo being a "big shaft" I'm not even sure what that means.
It was a mistake to even buy the thing
Old Apr 21, 2010 | 10:44 AM
busa4's Avatar
wow! 1.15 ar exhaust housing? thats a big ass turbo housing. its going to be some serious lag if it can even be spun at all.
Old Apr 21, 2010 | 02:39 PM
terry11's Avatar
haha k. that's what i thought I was just making sure. I'm not getting it. That means it's like 115mm correct?
Old Apr 23, 2010 | 11:40 AM
busa4's Avatar
no. it means the area of the exhaust housing. the larger the number the more area the housing has which means the bigger it is.
Old Apr 23, 2010 | 12:26 PM
06blackg85ss's Avatar
**** I run a 1.06a/r on my rx w/ a gt3582r, but on a cobalt you will never get that thing to spool, will make some sick top end power though lol.sounds like an ebay turbo to me
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
