Forced Induction Turbos/Superchargers
fuel pressure
Old Feb 13, 2011 | 04:14 PM
startingline05's Avatar
fuel pressure
what kinda fuel pressure would you run with 80's on a 2.8 tvs setup? this is without the vac line hooked up untill i can get tuned on e85
Old Feb 13, 2011 | 04:20 PM
BLAZIN07SS's Avatar
I'm too JDM for you
well you should tune immediately when going on return style. its gonna run like crap unless its tuned for it. stock is 58psi base pressure
Old Feb 13, 2011 | 04:22 PM
im trying to get tuned for it, i talked to a guy on here one time who tunes. i have sent him 2 messages on here but he must be busy cause i havent gotten a responce back
Old Feb 13, 2011 | 04:23 PM
BLAZIN07SS's Avatar
I'm too JDM for you
you don't have hptuners do you?
Old Feb 14, 2011 | 12:11 PM
no i wish i did. i have it set at 58psi. but when i get into it alittle bit the car acts like its running out of gas, should i just adjust up alittle bit more for now?
Old Feb 14, 2011 | 12:13 PM
ebristol's Avatar
The stock fuel pressure should be plenty for that pulley on gasoline. You might want to check your install.
Old Feb 14, 2011 | 12:16 PM
BLAZIN07SS's Avatar
I'm too JDM for you
whats the wideband reading when you get into it?
Old Feb 14, 2011 | 02:20 PM
Its reading a low 10 something at ideal and about the same at wot
Old Feb 18, 2011 | 08:12 AM
well i actually payed more attention to it, i got on it and my afr was at 10 and sometimes bumping up to a 10.1 and to a 10.2. i just dont understand why my car is doing what its doing. once i hit into the higher rpms usually around 6000 it will just stop untill i let off the gas and it will starting running again
Old Feb 19, 2011 | 11:45 AM
o and to add in there that it likes to cut off like its running out of fuel when i get to about a quarter tank left, so do u think the reason its acting like this is because i did something wrong when removing the stock regulator out of the tank?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
