Forced Induction Turbos/Superchargers
help finding t3 gasket
Old Jan 26, 2008 | 12:20 PM
mike25's Avatar
ive been looking around, and im having a hard time finding a t3 turbine outlet gasket. the turbo i have has a small hole for an internal wastegate. my question is do i need a gasket that will accomodate that or can i use one that will just block it off? seeing as how i wont use it..?
would this work:
Old Jan 26, 2008 | 01:22 PM
BlackSS/SC's Avatar
I'm pretty sure you can just use that gasket in the pic above.
Old Jan 26, 2008 | 01:24 PM
NJHK's Avatar
Don't you have a T3/T4? Show us a picture of your exhaust side. Count how many bolts you have and look for the a gasket that matches it.
Old Jan 26, 2008 | 03:51 PM
mike25's Avatar
yea i have a t3/t4...heres a pic
will that gasket i posted above work? looks like it will to me im just unsure about that internal gate hole
Old Jan 26, 2008 | 04:00 PM
Witt's Avatar
If you are using an internal gate, that first gasket won't work.
Check ebay or any local tuning shop. They should have the gasket.
Old Jan 26, 2008 | 04:04 PM
mike25's Avatar
no mines an external gate. would that work then?
Old Jan 26, 2008 | 04:22 PM
Witt's Avatar
Sure will. That internal gate hole should be blocked off by the flange on the downpipe.
Old Jan 26, 2008 | 04:27 PM
mike25's Avatar
ok thanks witt. just wanted to make sure.
Old Jan 26, 2008 | 08:05 PM
NJHK's Avatar
I would have said the same thing as witt but I wasn't home lol
Old Jan 26, 2008 | 08:36 PM
mike25's Avatar
lol well thanks to you too
Old Jan 26, 2008 | 10:13 PM
FacelessKhaos's Avatar
And if you were using an internal gate....indicate where the hole is...and gently cut it out...then it would work lol...but yeah...it'll work
Old Jan 27, 2008 | 12:00 AM
mike25's Avatar
yea i just wanted to make sure...this is a dumb question but...i dont think i do but for the turbo gaskets do i need to use and sealer or anything like that? and ive read of problems with turbo bolts working loose and such...do i need to put thread lock on them or will they be fine without it?
Old Jan 27, 2008 | 12:22 AM
don't use sealer...it's a high temp zone...the copper is there because it will expand and fill any micro spaces that are there...the sealer will just burst into flames and ruin stuff.....thread lock....? like an anaerobic thread lock? Loctite? maybe..we have put loctite on super high temp parts before and it always holds..thread tape...hell no...it will melt and catch fire...safe bet...torque them down and if it's going to be a permanent set up (meaning it will go with the car even when you sell it) then loctite it...if not..then check them every 5k or so....
Old Jan 27, 2008 | 12:35 AM
mike25's Avatar
thats what i was thinking...i just remember the sols having probs with bolts backing out and bending and such. hows it comming with your machine
Old Jan 27, 2008 | 01:00 AM
still waiting for the damn techs to show up...hell we have had ventilation problems in my weld shop for about 8 months...it took them until last Wed. to come out and try and fix it...now they "need a second pair of eyes" to evaluate their work...blah...i'm praying that the Fadal guy comes this week and fixes the problem....and if my supervisor would actually let me...i could fix it within 2 hours...but bosses you know...(i am the floor supervisor but i have a boss..and he has a boss...and so on and so forth)...all the machine is doing is trying to read a tape drive that is actually a floppy drive...so it's giving a BAUT error...when i was going to use it the machine tried to run the tool turret into the spindle head then froze up when i loaded the program...damn 8 year old CNC...lol...but it will be fixed soon...but i'm going to hit up my manual mill when i can and start some parts...
Old Jan 27, 2008 | 10:24 AM
mike25's Avatar
ok,sorry for all the troubles ya been havin, hope it works out. keep me updated. and thanks
dennis69
Oct 20, 2015 04:49 PM
agentirons
Oct 16, 2015 02:11 AM
Delta coupe
Sep 30, 2015 08:11 AM
Sep 28, 2015 12:51 PM
SlowSaturn
Sep 28, 2015 11:03 AM
