Forced Induction Turbos/Superchargers
How to deal with the wastegate
Old Sep 7, 2007 | 01:08 PM
stagezero's Avatar
well im not producing the boost i am suppose to be with my supercharger and i was wandering if it was because my wastegate is opening up too early......is there a way i can fix that to see if i can get the boost that i am suppose to be running? or what do i need to do?
Old Sep 7, 2007 | 01:10 PM
justin04's Avatar
boost bypass valve prolly has either a pin hole in it or its stay cracked open.... my dealership fixed mines at wot i would only boost 5lbs....
Old Sep 7, 2007 | 01:12 PM
SKDR112888's Avatar
wastegate? on a supercharger?
justin04's Avatar
its a bypass valve we dont have a wastegate
Old Sep 7, 2007 | 01:15 PM
NJHK's Avatar
Like said, you have a bypass valve, not a wastegate.
Your bypass valve is open when you're at low throttle positions and closes to hold pressure in the manifold (hence, your boost).
Take it to your dealership cause it could be a couple things. It's hard to diagnose over the internet.
hacadacalopolis
Oct 28, 2015 06:09 PM
TedSS
26
Oct 10, 2015 04:30 PM
jcarroll53
Sep 24, 2015 07:43 PM
