Forced Induction Turbos/Superchargers
How to make a custom turbo downpipe?
Old 12-08-2007, 11:44 AM
mike25's Avatar
does anyone know a how to or something that will help me make a custom downpipe?
Old 12-08-2007, 01:40 PM
FacelessKhaos's Avatar
actually i am about to make one myself...it's not hard at all...just need metal, a welder, measurements, and a milling machine....
metal:
you have to ask yourself a few questions
Do you want to go cheaper on build cost?
Do you want it to "look pretty"?
so performance isn't going to be an issue if you choose the right material from the start.
Carbon steels are an acceptable choice and cheaper to get compared to stainless steels. Stainless Steel usually require an experienced welder and are sometimes much harder to machine than carbon steels. Material grades i suggest for Carbons steels would be 4130, 4340 about 1/4" -3/8" for the flange.
Material grades i suggest for Stainless Steels would be 301, 304, and 409. The stainless that is best for exhaust is probably 409.
However, material thickness for the tubing now is an issue...if you go too thin with carbon steels, it will heat up too fast and fail faster. With stainless steels, if it too thin and heats up too fast, it will contaminate and you run a higher risk of major failure.
So, with carbon steels, i suggest a wall thickness of no less than .1875-.250" of an inch (3/16" to 1/4") and if using carbon steels, it's highly recommended to have a high temp coating also added, ie. Jet-Hot, ceramic coating etc.
With stainless steels, i suggest a wall thickness of about .125-.1875 (1/8-3/16)
now with that....if your turbo can just have a pipe clamped on...best bet is to take it to an exhaust shop that can mandrel bend (not a crush bend) and have them bend it to the right specs for your vehicle.
either way, make sure they are at least 3" inner diameter.
Flanges:
Machining flanges probably can be the most difficult part of the process. Most flanges today are produced via CNC Machining Centers where every flange that is produced is nearly identical. There are places that already have flanges that you can buy which aren't that expensive. But the problem there is what material they are using...if you buy a stainless steel flange with a carbon steel pipe, welding is not going to be an option. Cross welding carbon and stainless steels will crack...they will fail and vice versa.
best thing to do is gather your dimensions straight from the turbo (if making a flange that bolts on to the turbo) and get the dimensions from where the exhaust flange is going to bolt into. Lay that out onto the material you have chosen. Now if using carbon steels and you have a lot of excess metal...best way to extract that template is to plasma cut about 1/8-1/4 away from the said lines that you have put on the metal. (Contour Saws can work but they are time consuming) For Stainless steels this is not an option considering that after you are done, the metal is no longer usable for the simple fact that you have contaminated the entire piece. (Stainless must be melted in an inert atmosphere, aka argon, helium only and since most plasma cutters use compressed air, it will contaminate because of oxygen, carbon dioxide, nitrogen content) So use either the mill or a contour saw to extract it.
Set it up on a milling machine with a good sharp cutter making sure that you know what you are doing and all the safety procedures are followed (no long sleeves, loose hair, NO JEWELRY RINGS WATCHES ETC.) Make sure your setup is strong, and allows for maximum machining per side. Best thing for this and if you don't know exactly what you are doing...take it to a machine shop and have them do it. Machine the piece out using all standard feeds/speeds and de-bur it using a file and sandpaper.
Now test fit it to the turbo/exhaust to make sure side clearances are within what you need them to be. Transfer punch the holes and drill and/or tap the holes...now you have a flange blank.
Before you cut the holes out for the pipe, make sure you have the pipe ready. line it up on the flange blanks and outline them. Cut the holes using one of the ways discussed before (however if you do it with a contour saw, you have to break the blade and weld it before you can use it)...
position everything and get ready to weld.
Welding:
this is highly important, not following the right welding procedure can cause failure in the part being made.
anything can be TIG (tungsten inert gas) welded, but if using carbon steels you can either use MIG (GMAW, gas metal arc welding), Stick welding)
if using stainless, then go for TIG welding and it will be better to goto a weld shop and have them do it unless you have experience in this kind of welding.
position everything and put a tack weld at four locations....now make sure that this is where you want everything to be before final welding. if you need, break the tack welds and grind them down reposition and when you have got it right...do your final weld.
When you do the final weld, don't do it all at once...instead go in sections to avoid warping. weld one section first, then the opposite, then another section then the opposite. it can be done from 4-8 welds per pipe. after all welding has been completed...wait for it to cool then make sure nothing shifted...
clean the entire thing off with a wire wheel and get ready for final machining of the flanges
set the flange parts up so that the bottom end will be cut (face milling)
take a light cuts until they are glossy and even on both flanges. de-bur all sharp edges...
then send that thing off for coating...
but all in all...unless you have some years of experience, goto a machine/welding shop for this...it isn't something that can be done in your garage at home nor shop beginners try and do...let the experts handle this sort of build.
pictures of the exhaust header i'm currently working on for my turbo setup
i haven't done the final porting on this yet nor the final machining and i used 4130 stock for the flanges with schedule 40 piping for the exhaust routes.
Old 12-08-2007, 09:43 PM
mike25's Avatar
thanks for the help...very informative....how would i go about doing a downpipe? like what bends would i need and stuff?
Old 12-09-2007, 12:32 AM
that depends on a couple of factors...
1. the angle in which the turbo is set up (assuming that your turbo needs a flange)
2. if you have an aftermarket exhaust and where it sets in relation to the header/turbo setup
3. the distance between the turbo and the exhaust flange
4. and do you have access to a machine/welding shop and are you experience in both fundamentals
what i would do personally (in which i am going to do) is at the last 4-6 inches of the down pipe, put flex exhaust pipe there so it gives you a bit of sway...but you don't want it to do a sorta "s" shape because that would create power robbing back pressure which you don't want...you want gentle curve and that's it...no more than one bend that is slopping)
but ideally you want only one 90 degree long bend...like a 6 inch radius bend and if you have an internally wastegated turbo, then a extend the downpipe tube in kind of an ellipse like a sleeker figure "8" shape, with the smaller part over or close to where the actual wastegate valve is at making sure that you have plenty of wall thickness between the outside and where the tubes are going to be welded. This ensures strength and clearance for studs and/or bolts. (much like what you see on the Garret style internal wastegate turbos)
http://www.turbobygarrett.com/turbob...e/Alpha-LR.jpg
(like the downpipe in that link above)
measurements always take precedence in these builds, you can't afford to be off so much as 1/32" of an inch or less....
measuring tape, calipers and micrometers are your best friends when it comes to this sort of build. Measuring tape will get you close, calipers for accurate close measurment and micrometers for dead on accuracy.
and if you are planning on machining let me know and i will tell you what cutters, grades, speeds and feeds are optimal for machining performance (the brand and model of machine is a big help too lol)
i am a machinist and certified welder in stainless steel, aluminum, titanium, and inconel by trade so whatever you have questions on these things feel free to ask
Old 12-09-2007, 12:41 AM
pimpnwink's Avatar
uhh i smell a sticky. lol
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
RaginChopsuey
10-27-2015 01:27 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
09-26-2015 06:44 PM
Quick Reply: How to make a custom turbo downpipe?
