Forced Induction Turbos/Superchargers
how to smooth out inside of my manifold
Old Dec 27, 2007 | 11:32 AM
mike25's Avatar
how can i smooth out some of the rough welds and edges inside of my manifold? theres a couple id like to get rid of..just curious if theres a way i can do and what do i need or if i have to send it off...?
Old Dec 27, 2007 | 11:34 AM
XM15's Avatar
Do you mean the stock exhaust manifold, or a manifold that you had fabbed for the turbo in your sig?
Old Dec 27, 2007 | 11:37 AM
ItalianJoe1's Avatar
Send it to me, or get a die grinder/dremel with a grinding wheel and do it yourself. Its not too hard, just watch your material thickness so you don't create a thin spot that may weaken when heated too hot. Thats if you are talking about exhaust.
Old Dec 27, 2007 | 11:49 AM
mike25's Avatar
yea its a turbo manifold...the manifold has a wastegate hookup plumbed in right above the manifold outlet flange...its a little bit rough and has some rough edges and i would like to smooth it out some...ill post up pics when i get a chance
Old Dec 27, 2007 | 11:51 AM
XM15's Avatar
Do what ItalianJoe recommended. Just get a dremel and spend some time on it.
Old Dec 27, 2007 | 12:01 PM
If its bad, get a 1/4" die grinder and a regular metal grinding bit. Thats what I use to open up the stock cast manifolds, stainless is a little harder material but you won't need to remove too much. Should be pretty simple.
Old Dec 27, 2007 | 01:12 PM
mike25's Avatar
ok i will...i get some pics up and see what you all think
Old Dec 30, 2007 | 03:59 PM
Maxim_X's Avatar
Like going from this:
To this?
I sent mine out to a shop I'm sure you could get the inside fine alone but I had my mating surface planed as well.
Old Dec 30, 2007 | 07:14 PM
That is something you could do yourself with a dremel/ die grinder, but not the planing. I could take it to work and plane down the flanges, but that is a little above the average home mechanic. Unless you have a belt sander.
Old Dec 30, 2007 | 11:04 PM
mike25's Avatar
i dont need any planing done...the flanges are perfectly flat...just need to smooth out the inside a bit
Old Dec 30, 2007 | 11:13 PM
ecotecon18s's Avatar
i did that to the CA header i bought...smoothed the primaries down and tapered the edges down the where it meets the flange. i didnt really mess with the DP outlet, but i took a wire wheel to both flanges to clean the paint off where it had been previously painted
Old Dec 31, 2007 | 12:20 AM
ptrblkz24's Avatar
What kind of manfiold are you using?If its the ebay manifold,i can bet you that the flange is gonna be warped.I bought 2 of those manifolds.one for my cavalier and one for the cobalt.I sold both of them before i ever had a chance to use them,and both of them were garbage.I would never buy another one of those manifolds again.The welds were sloppy and the runners werent even lined up properly.
Old Dec 31, 2007 | 10:12 AM
mike25's Avatar
ive already got the mani and the flanges are perfectly flat...(thanks to vulcanturbo)...got an excellent deal from him and one nice looking header...ill get some pics up as soon as i get the turbo in
Old Dec 31, 2007 | 06:42 PM
ptrblkz24's Avatar
Oh,ok good.I thought you had that ebay crap for a minute.
Old Dec 31, 2007 | 09:33 PM
mike25's Avatar
lol it was my first option but then i stumbled across this header
DarrenGC
Dec 24, 2021 01:55 PM
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
Oct 13, 2015 09:32 PM
Sep 27, 2015 08:53 PM
