Forced Induction Turbos/Superchargers
im at a lost
Old May 5, 2008 | 03:55 AM
Jn2's Avatar
Jn2
im at a lost
ok guys just saw a cobalt running turbo with out tuning, drove it around, no limp mode, rev it as high as 4000rpm, so limp mode, i have gotten limp mode b4, so i know i coulndt get past 3k b4 my car shut down almpst all its power, how is it it can sustain boost w/out tuning?
ps-his thread is on the 2.2 section
Old May 5, 2008 | 03:56 AM
M-Dub's Avatar
At a loss I think is what you were goin' for there!
Old May 5, 2008 | 03:58 AM
cobalt_driver's Avatar
some cars can. my buddy has an eclipse with a turbo and never tuned, n he runs 5 psi. after about 4k though he bogs horribly. i can beat him with my 2.2 with an intake. but, idk. its dumb though to run without tuning. totally stupid.
Old May 5, 2008 | 04:25 AM
Jn2's Avatar
Jn2
yeah he didnt rev past 4kish, im thinking car hit limp after that..not sure
Old May 5, 2008 | 05:02 PM
2K5SS/SC?'s Avatar
I don't know, but don't do it! BOOM = BAD!
Old May 5, 2008 | 05:04 PM
HackAbuse's Avatar
I bet the spark plugs are WHITE
Old May 5, 2008 | 05:19 PM
IonNinja's Avatar
i've never heard of an official limp mode for 2.2's
no/crappy tuning is one thing
the only time I've ever had my car lose all its power and throw CELs is when I had faulty nitrous wiring...
Old May 5, 2008 | 05:20 PM
Psykostevo's Avatar
*edit* never mind
I have a friend here with a 2.2L cavlier that has a turbo setup. He uses bigger injectors and no tuning. Dude pulls high 12s in the 1/4 and has put 60k miles on the setup. Don't ask me why it has lasted so long, but I know the long version of the science behind it.
Reason it idles: The car will do WHATEVER it can to try to get itself to idle, regardless of the bigger injectors.
Reason it pulls like an ape: When he floors it the bigger injectors dump enough fuel in to compensate for the lack of a tune. Instead of commanding a proper 11.8 AFR it commands a 13 and ends up with like a 10.xx because of the fuel injectors not being compensated for like they are at cruise/idle.
Old May 5, 2008 | 05:24 PM
mrsilent13's Avatar
is that my car ur talkin about
Old May 5, 2008 | 09:17 PM
Jn2's Avatar
Jn2
yes sir mr silent
Old May 5, 2008 | 09:23 PM
mrsilent13's Avatar
yes sir mr silent
lol...yea she idles fine ...but im boosting real low right now....like 1 pound...im playing it safe you can say but ill bump her up to some more once i get my exhaust done mayb 4~5....once i get tuning ill bump her up to about 8~9 pounds...then it will be fun...but already i can feel the change...i love it....she pulls hard....and since its automatic....my boost stays constant until i left off the gas.....
Old May 5, 2008 | 09:56 PM
Sw4y1313's Avatar
No offense but thats really stupid to not have ANY tuning at all. Get a AEM FIC and tune it, then get a reflash from vince that just takes away the governor and PE Delay. Then your golden, you can retune whenever you want.
Oh yeah, you will go into limp mode if the fuel trim is off by +/- 10(it may be a little higher though). My car would go into limp mode sometimes in first gear because i would be at like 50% throttle and it would rev so fast the ECM was seeing too much change in the fuel trim and it would throw it into limp mode when it was cold.
Old May 5, 2008 | 10:34 PM
mrsilent13's Avatar
its all good man...i know its not the best way but i just had to install it....ill get tuning as soon as i get back from vegas...so no worries...the car will be sitting for a while.....im just driving it to and from work right now....and well 2morrow is my day off...so ill probably install my turbo timer and wideband sensor
Old May 6, 2008 | 12:35 AM
Jn2's Avatar
Jn2
how did you pull off 1psi? the turbo you have is internally wastegated, the lowest setting i have seen is 7-8psi, howd u get 1? i dont think boost controolers can loswer the boost lower than what the wastegate is set too
RaginChopsuey
Oct 27, 2015 01:27 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
Superslowbaltt
Sep 22, 2015 10:24 AM
umrdyldo
Sep 21, 2015 05:28 PM
