Forced Induction Turbos/Superchargers
injector question for the 2.2 supercharged
Old Feb 13, 2010 | 09:35 PM
jonxxxedge1's Avatar
ok im gonna be going supercharged soon. whats the best injectors to go with? is it alright to go with 60's right away? and is there anyone that make plug in injectors for the 2.2 instead of hacking up the harness? if so what ones are they, ev1, ev6?
Old Feb 13, 2010 | 11:06 PM
jbenso4's Avatar
de[ends what you plan on doing with the motor...If you just go stage 2 42#'s are youre best bet. unless u plan on building the motor with more boost than stage 2 get the 60's
Old Feb 13, 2010 | 11:38 PM
i only plan on using stock pulley for now then come summer build and boost more. but can i use 60's on stock pulley?
Old Feb 14, 2010 | 12:31 AM
troyss's Avatar
No use, just use the 42's that will be the best
Old Feb 15, 2010 | 12:23 AM
alright and can i use a lsj alternator?
Old Feb 15, 2010 | 12:13 PM
ipwncivics's Avatar
yes, if you want to use LSJ alternator get the rest of the parts to, so you can run all belt ribs, crankshaft pulley etc
Old Feb 15, 2010 | 11:07 PM
will i also have to swap the pulley from the ac?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
