Forced Induction Turbos/Superchargers
low boost question
Old Jul 30, 2009 | 10:04 PM
06cobalt racer's Avatar
low boost question
ok with my mods that i have below i am only getting 14.2 psi of boost. i already checked for belt slip and i dont have any. when i hit 14.2 it was at the top of 2nd gear at 7000 rpm. this seems really low for the 2.8 pulley that i have with the ott stage 1 kit. what are some other factors that could cause low boost? it runs rich but i dont think that would have anything to do with boost would it? what do you all think?
Old Jul 30, 2009 | 10:07 PM
DeepBlack SS's Avatar
the exhaust work could explain a couple psi
Old Jul 30, 2009 | 10:13 PM
gearhead07's Avatar
is the bypass hanging open? try the boost bypass mod and this will tell u if that is bleeding off some boost then u will have to go from there.
Old Jul 30, 2009 | 10:15 PM
gearhead07's Avatar
Old Jul 31, 2009 | 02:32 PM
ok well i did the bypass mod. ran it the exact same way as i did with the 14.2 psi run. only difference is that ambient is 10 deg warmer this time. well i got up to 14.5 at the same rpm. so i dont think it is the bypass hanging open. what else could it be?
Old Jul 31, 2009 | 09:32 PM
Gene Culley's Avatar
Talking
I have heard of this issue being the tune when the bypass mod doesn't fix it.
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Slick_Nick
Sep 28, 2015 09:15 PM
OPCrer
Sep 27, 2015 08:11 PM
