Forced Induction Turbos/Superchargers
LSJ turbo intake manifold restriction HELPP
Old 12-06-2013, 10:00 AM
i944scania's Avatar
Im running those zzp lsj intake manifold adaptor plates for the lsj.
My maf cuts out if i run more than 14 psi of boost, starting around 6krpm.
If i turn the boost down to 12 or so, i can rev the enging all the way out. But at 14/6k i can monitor the MAF Hz drop and the car/rpms freeze.
Does anyone run these plates? or have information that the stock lsj manifold is too restrictive for my to4e 50 trim .63?
I do have a 2.5" exhaust catless as well
Old 12-06-2013, 10:05 AM
Bass_Waves's Avatar
why not just buy the modified manifold from zzp? they only like 200$
Old 12-06-2013, 10:06 AM
Bass_Waves's Avatar
boy was i wrong. they 350 lol
noorj's Avatar
the intake manifold is not too restrictive and is not the cause of your problem.
what is the size of the pipe your maf is in?
Old 12-06-2013, 10:15 AM
i944scania's Avatar
when i did the build last year, the manifolds were kind of pricey. So for the sake of getting the car back together, i went with the plates.
Its 2.5" intercooler piping, the maf housing is a little under 3"
Old 12-06-2013, 11:01 AM
armcclure's Avatar
That's the problem. Not the IM.
Old 12-06-2013, 11:02 AM
noorj's Avatar
beat me to it
Put the maf in a 3 or 3.5" pipe
Old 12-06-2013, 01:59 PM
i944scania's Avatar
Measured today. The Maf is in a 3" housing.
Old 12-06-2013, 02:26 PM
noorj's Avatar
whats your maf fail set to
Old 12-06-2013, 03:39 PM
jp1600's Avatar
Ill bet there is a problem in your torque management tables, your boost is probably limited to the stock 12lbs
Old 12-06-2013, 03:50 PM
noorj's Avatar
i highly doubt that
Old 12-06-2013, 03:56 PM
jp1600's Avatar
Just an idea, either way, he turns the boost down to stock level and its fine
Old 12-06-2013, 03:57 PM
Have you ever used hp tuners? Lol
Old 12-06-2013, 04:00 PM
jp1600's Avatar
Yup, i have, and do, just throwing out an idea, could very well have his maf fail set to 10,000, just throwing out an idea, no need to be hostile
Old 12-06-2013, 04:05 PM
armcclure's Avatar
That's irrelevant. Catch up.
Edit: not being hostile. Just stating tq management is irrelevant when he's using none if the sensors/solenoids that control it.
Old 12-06-2013, 04:11 PM
jp1600's Avatar
Good point lol
Wasnt really sure if any of the values would be used
Old 12-06-2013, 06:25 PM
i944scania's Avatar
Everything was tried..we explored any may issues that could be holding the system up.
Also, 12 psi isn't a stock pressure because it was an LSj sc. Now its an aftermarket turbo that pushes much more air than the m62. So whatever pressure I set it to, its kinda far from stock
Old 12-06-2013, 06:26 PM
i944scania's Avatar
So there are no ecu related controls for my boost.
Old 12-06-2013, 06:30 PM
ItalianJoe1's Avatar
What is your MAF HZ value when it dies?
Old 12-06-2013, 06:36 PM
jp1600's Avatar
Yeah i get what your sayin 944, i've only messed with sc, i was thinking about unused tables, mcclure got me on the right path there. Sittin back w my popcorn
Old 12-06-2013, 07:11 PM
i944scania's Avatar
I can't remember, I'd have to ask my tuner. But it the frequency would climb normally with the rising airflow and then start to stop around 5800rpm and the car starts to slug. Then at like 6k the freq dropped to like idle freq when still pushing air at 19psi
Old 12-06-2013, 07:13 PM
i944scania's Avatar
I mean, it feels like a clogged cat! Car completlry falls on its face. Unless I run 12 psi or lower it seems to rev out well. The waste gate dumps well at that lower psi. Even at 15psi it did but as soon as it hits that high rpm spot, gives out and the waste gate dump sound horrible
Old 12-06-2013, 07:44 PM
Bad-A-SS's Avatar
Have your tuner to send you some screenshots and then post them for us to see bud
Old 12-06-2013, 07:52 PM
armcclure's Avatar
Logs would be better.
Old 12-06-2013, 08:00 PM
i944scania's Avatar
Anyone Wanna Take A Look?
I dont know how to view the HP file, i dont have the soft ware. but my tuner posted on this forum. Maybe you guys can view it. the tune has changed since then slightly.
Quick Reply: LSJ turbo intake manifold restriction HELPP
