Manifold
Manifold
Ok, this winter im putting my 2009 ss/tc sedan under the knife. Im gonna use the stock turbo or a 50 trim if I can get my hands on one but my biggest question is what manifold i should be making. I AM going to make my own manifold with and external wastegate but cant decide if a top or bottom mount is better. I hear the top mount has better spooling but idk. any insight would be appreciated guys and gals.
*design for spacial confinements and service-ability
*runner diameter
*runner length
*merge collector design
*optimal wastegate port placement
*correct sized wastegate for boost ran and turbo sizing.
All else is fluff
how would it being a top or bottom mount effect spool time??? build whatever u prefer but keep those things that should be worried about up above in mind. do u want to see the turbo or do u want to see some tubing behind the engine? just make sure u take into consideration, ur oil drain placement, wastegate placement and down pipe placement.
mike
mike
manifold
ok. yes i would like to see the turbo. i finally got my hands on a 50 trim. i just got the flange for the head from GM Performance parts and am ordering the others now. I have heard that a top mount helps the turbo spool faster but i have also heard that it helps with tight engine compartments which ours r. o by the way, would making it unequal lenghts really give it a subaru boxer rumble? wouldnt that be kinda shitty for the spooling? my goal is fast spool, big boost, 400+ hp
yes, unequal length headers is the reason why subarus sound the way they do, has nothing to do with the engine. heres a HONDA with unequal length headers.
YouTube - EK Hatch Exhaust Test
mike
heres the thread from JBO about it.......
page 5 has the engine rebuild pics
aaron's (aka blueboost) new AMMFAB turbo setup is done! - Boost Forum - j-body.org - the jbody organization
mike
im not to sure about the manifold as i went with a vulcan, but charge pipe wise i hear 2.5" hot pipe and 3" cold is a good combo. i guess it all depends on the volume of air your movin tho
mike
PIping
Im aiming for 400 hp. Y is the cold side bigger? i dont under stand that? Im having a local shop bend the exhaust piping for me so in thinking the 1 5/8 is good. also, where can i find the flanges for the MAS and AIT sensors to weld into the pipe?
You might max out the maf frequencies then.
or u could just twin charge it!
overboosted........... the cold side is bigger cause thats what the owner wanted, it also matches up pretty close to the throttle body compared to 2.5" and personally i think it just looks better then if it were 2.5" piping there. theres no real benefit to doing it like that in case u were wondering.
mike
