Forced Induction Turbos/Superchargers
Map question???????
Old Feb 29, 2012 | 07:31 PM
1LowLS's Avatar
Map question???????
So I keep hearing my stock MAP sensor is a 1 bar sensor which is 14.7 psi.If true,why does my manifold pressure on my torque app only show 1.3 psi,but my gauge shows 13 psi?I know the gauge isn't running of the ecm being it's mechanical,but is the ECM not capabble of reading over 1.3 psi,or is it the map sensor?I'm a 2007 2.2L.
Old Feb 29, 2012 | 07:34 PM
BankerBalt's Avatar
you need a different map sensor.... stock sensor is not meant to handle boost applications. get an LSJ stock map
Old Feb 29, 2012 | 07:45 PM
1LowLS's Avatar
I have one but has to be wired in.How is my stock MAP "1 bar" if it can't see past 1.3psi?That makes no dam sense haha.I just need a pigtail for a LSJ MAP and it's going in.
Old Feb 29, 2012 | 07:48 PM
BankerBalt's Avatar
i bought a pigtail for the lsj one and rewired it for about 25 bucks
Old Mar 1, 2012 | 01:13 AM
bluebalt07's Avatar
I don't understand the "bar" meaning either lol but the LSJ MAP will solve that issue and it is also the best for tuning
Old Mar 1, 2012 | 11:15 AM
nhanson's Avatar
Where from?
Old Mar 1, 2012 | 11:18 AM
drumrush's Avatar
My harness alone was like 60 bucks, and I think I lost my lsj map lol
Old Mar 1, 2012 | 11:19 AM
BankerBalt's Avatar
I think ced, not sure. Find the part number and Google shopping search it. I dony have the pn off hand at work here
Old Mar 6, 2012 | 01:03 PM
busa4's Avatar
1 bar map sensor reads 30 inhg (vacuum) to 0 atmosperic pressure. the atmospher at sea level is 14.7 psi which is all the weight of all the oxygen and oher gasses pressing down on you. a naturally aspirated engine can only such in 14.7psi of air at sea level. on a boosted application, the engine is now sucking in atmospheric pressure at 14.7 psi + boost pressure(all pressure over atmospheric pressure). this is why a 1 bar map sensor reads 14.7 psi which is atmospheric pressure. when you purchase a 3 bar map sensor, the map sensor will read 14.7 psi atmospheric pressure(vacuum) with the first bar then on the second bar it will read 14.7 psi boost above atmospheric pressure and the third bar will read another 14.7 psi for a total of 29 psi boost.
simple! right?
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
Extremespeed
Sep 29, 2015 04:34 AM
Adiaz1ss
Sep 26, 2015 11:51 PM
