Forced Induction Turbos/Superchargers
Methanol Question
Old Oct 10, 2008 | 07:05 PM
blazinbaltss's Avatar
Methanol Question
hey guys i just put my devils own meth kit on but when i turned it on to see if it was spraying into the throttle body i saw nothing any ideas what could be the problem
Old Oct 10, 2008 | 07:08 PM
burnrubr88's Avatar
Grounds? go through everything again to make sure its wired correctly. usually grounds are 99.9% of the problem with electical problems.
Old Oct 10, 2008 | 07:09 PM
rwally
Old Oct 10, 2008 | 07:10 PM
burnrubr88's Avatar
^whah?
Old Oct 10, 2008 | 09:12 PM
bump everyone agree it might me a ground
Old Oct 10, 2008 | 09:15 PM
CobaltLs_14's Avatar
Whats ur mix gonna be?
Ex. 75% or 60% or 50% or 30% or 25% and so on...
Oh yeah i agree ground (most likely)...
BLAZIN07SS's Avatar
I'm too JDM for you
the meth kit doesnt spray all the time. its controlled by the map sensor and turns on with boost
Old Oct 10, 2008 | 09:27 PM
i think there is half and half in there now but anyway the relay thing is it suppose to be grounded to the car?
Old Oct 11, 2008 | 12:34 PM
hey guys well i have everything hooked up for the meth still but i ran like a voltmeter and all the wires are good i mean i will probably have some one look at my grounds but i heard once you hook it up you shouldnt have to start your car to hear the pump i would really appreciate it if someone could take a picture of the fuse box thing in the engine bay and a picture of where the put the t connector and pictures of where they grounded the wires
thanks brian
Old Oct 11, 2008 | 12:36 PM
BLAZIN07SS's Avatar
I'm too JDM for you
thanks brian
did you hook up that piece to your MAP sensor? the kit turns on with boost, its not gonna spray meth at idle. when you supply power to it, the pump is "ON" but it will only start pumping meth when it hits a certain amount of boost
Old Oct 11, 2008 | 12:53 PM
first off whats the map sensor and when i drove it there was still nothing coming out of it? but when everything was hooked up the way it should when i would hit 6lbs of boost the car felt weird like it was stuttering so i unpluged it
Old Oct 11, 2008 | 12:59 PM
lsjwannabe's Avatar
thats because the car was running super rich get it tuned you had it right.
Old Oct 11, 2008 | 01:14 PM
yea im going up to tune time next week for a dyno day but matt told me to have everything put on before i got there at least i tryed they should be able to fix it up there!!
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
