Forced Induction Turbos/Superchargers
Need help deciding turbo
Old Nov 23, 2012 | 05:48 PM
Chevycobaltss3's Avatar
Yep
Old Nov 23, 2012 | 11:25 PM
BankerBalt's Avatar
ok now i'm confused... the s20g on hahns site shows that the charge pipe goes under the engine...?
Old Nov 23, 2012 | 11:44 PM
That's for Hanhn kit... You can route your piping how you want it....
Old Nov 23, 2012 | 11:59 PM
BankerBalt's Avatar
sorry... with all these different turbos, downpipes, intakes and charge pipes, this crap does get a bit confusing as far as compatibility goes... i'm not the kind of person that will buy the same kit a lot of people have, i'm just used to an m62 mounting one way and everything from an LSJ to be completely compatible with everything
Old Nov 24, 2012 | 12:09 AM
What you need to do is get the turbo, both manifolds/ inner cooler, and work routing from there.... I would use the LNf system other then the lower pipe..
Old Nov 24, 2012 | 12:20 AM
BankerBalt's Avatar
erright that seems fair... last question then... turbo is water cooled? where do i tap for that?
Old Nov 24, 2012 | 12:59 AM
You don't have to tap... You don't have to run the coolant lines. But if you do, you can run one inlet from the coolant neck o head and recirculate to where thermostat is or tap block
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
bigdeertz
Nov 17, 2016 09:41 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
maliki778
Oct 1, 2015 07:39 PM
