Forced Induction Turbos/Superchargers
Pulley Puller question
Old Dec 4, 2007 | 01:36 PM
SmOKe JeNsOn's Avatar
i'm going to rent one from Autozone I called they said the only one they have is a 3 jawed? Is that the one I need
Old Dec 4, 2007 | 01:37 PM
Rangerondubz's Avatar
You can pull it with that one but you will not be able to put the hub back on
Old Dec 4, 2007 | 01:38 PM
redlineblueline's Avatar
power steering pulley installer will work to put it on though
Zzp Ftw
Old Dec 4, 2007 | 01:39 PM
I got the hub and the pulley from nate so this one would be ok to use? is there any better one ( or easier one to use) if i can find it? yea but this is free just leave a deposit and they give it back when u return it
Old Dec 4, 2007 | 02:22 PM
nherbst454's Avatar
Here's one that I know of, feel free to pm me if you're interested.
It's used to pull the stock pulley off and press the new pulley on...
Old Feb 18, 2008 | 12:10 PM
Ok bumping this back up Trying to get the pulley put on today. also will I need a new gasket for the supercharger?
Old Mar 23, 2008 | 06:52 PM
Leatherwood's Avatar
what do you need to get the hub out is it a pulley puller?
will the zzperformance puller work?
Last edited by Leatherwood; Mar 23, 2008 at 06:52 PM. Reason: Automerged Doublepost
Old Mar 23, 2008 | 08:49 PM
Zooomer's Avatar
Supporting Vendor
ZZPerformance.com makes the best, easiest to use, most complete puller on the market. It will install and remove a factory pulley or a modular hub. It will remove a modular hub as well with use of a backing plate.
Old Mar 23, 2008 | 09:08 PM
nherbst454's Avatar
You will need a backing plate that I can make for you as well as a puller such as the one at http://www.smoothflowpulleys.com/Pulley_Puller.html
brandon04
Oct 21, 2015 07:04 AM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
