Pulley question??
Pulley question??
I was wondering if the gm stage 3 pulley would work with the stage 2 kit? Mods I currently have are GM stage 2 kit installed, ZZP 3 inch catless dp, GM header, GM full exhaust, Injen Cai, Front mount ZZP heat exchanger, ingalls torque dampner.
not sure of the size of the gm pulley but im guessing it would work, however, you would need a new tune. Depends on what the size difference is. And its a big difference you may need different fuel injectors
the amount of force to get it pulled varies with every supercharger. A lot of people took theirs off with no problem, but there are some pullies out there that'll actually break the puller cause they just don't wanna budge. Mine broke like three different size pullers.
As far as the size of the stg 3 pulley, it's only a 76mm pulley, and the stg 2 is 77.9, so that roughly comes out to 2.99", which should be fine. But don't go any lower with those injectors or tune.
o wow.. to change from the stage 2 to stage 3 pulley you dont need to press anything.. all you need is the gmstage 2 pulley key. alot of people on here have it.. you have to take off the supercharger, get the key to remove the 4 bolts, and then reinstall.. no press needed as you already have the stage 2 hub.. i just changed my stage 2 pulley to a nates 2.95 and i love it.. more low end power
Buy a 2.95 or 2.9 and swap it on there the same and you'll be happier
-You don't need cooling mods if you have a pulley bigger than 2.8". I'm not saying don't get it, but it's just not necessary.
-You don't need to tune JUST for a pulley change. The only you would get a tune is if you have to change injectors. the duty cycle of the 42lbers might go up, but it'll still be within reason.
yeah...but we're not talking about going lower than 2.9", so there's no necessity to get cooling mods. However, you could if you wanted, if you had the extra 200 bucks to spend and you don't have bills.
I just had my 2.9 pulley and my ZZP heat exchanger installed and i love it. The coolilng mod is def worth it. The blower is now cold as well as the coolant hoses. Huge difference.
patooyee
Oct 1, 2015 01:07 PM
