Forced Induction Turbos/Superchargers
Pulley swap
Old Jul 10, 2006 | 03:16 AM
05sss's Avatar
Pulley swap
Hey whats up-
Im planning on swapping out my stock supercharger pulley for a 2.858" pulley. Working off a limited budget, are there any upgrades that have to be done with that; or anything I should know before preforming this???
Thanks- Luke
Old Jul 10, 2006 | 10:10 AM
chevytech007's Avatar
You should at least have 42.5 injectors and a maf-t or some other thing to control fuel.
and colder spark plugs to be safe.
im putting my 2.8 in this week with this setup i can let you know.
Old Jul 10, 2006 | 10:12 AM
CTCOBALTSSS's Avatar
Exactly
42.5 injectors
1 step colder spark plugs
MAF-T
Old Jul 10, 2006 | 05:16 PM
05sss's Avatar
cool thanks
Old Jul 10, 2006 | 05:26 PM
Tomtwtwtw's Avatar
I believe to go that much smaller with no other mods, you will need a shorter drive belt or a larger idler pulley as well.
Old Jul 10, 2006 | 05:27 PM
budman128's Avatar
yeah your factory belt would slip like a bastard
Old Jul 18, 2006 | 08:07 PM
BlueSS-supercharged's Avatar
umm not quiet, the stock injectors have been proven to provide enough fuel for most applications. i have been running my stockers with my 2.9 pully for a while and no problems no fuel cut off and no lag. and for the belt yes you will get a lot of slipping at first but when the belt seats its self and with a little belt dressing it will be fine. mine only squeeked for a few days then i was fine
Old Jul 18, 2006 | 08:20 PM
BLKSS's Avatar
Thats all false. He will get massive slip and run out of gas at 5000.
Old Aug 9, 2006 | 05:24 PM
dude i run it every day and not sence about a week after i put the pulley on has slipped, i just used a little belt dressing and it seated perfactly
Old Aug 9, 2006 | 05:25 PM
but i have to do this every one......100 postes after almost a year of being a memeber heck ya!!!
Old Oct 5, 2013 | 08:25 AM
jaactaz's Avatar
I am going from stock to 60lb. injectors and adding 2.8 pulley what size belt do I need?
Old Oct 5, 2013 | 10:50 AM
the gm stg2 belt exact size idk but the tensioner kind of picks up the slack
Old Oct 5, 2013 | 11:04 AM
VapeWI's Avatar
Not one of you said upgraded heat exchanger, dual pass, or option b? **** I'm running the stock GM stage 2 pulley and I wouldn't go lower if I didn't have those things.
Old Oct 5, 2013 | 11:27 AM
06cobaltncng's Avatar
definitely upgrade that ****.
Old Oct 5, 2013 | 12:47 PM
Whitnith's Avatar
Look at the dates.... in 06 that stuff was only for the crazy high end builds.
Old Oct 5, 2013 | 02:22 PM
CobaltSS 16's Avatar
wow how times have changed
Old Oct 5, 2013 | 03:17 PM
jHarris8822's Avatar
Exactly what I was thinking. I was reading this like " why the hell has nobody said stage 3 h/e, headers, option b, dual pass, etc. Etc. Etc" ....then I realized this thread happened back when cobalts were still infants lol
Old Oct 5, 2013 | 05:07 PM
Tomtwtwtw's Avatar
****, I was running a 2.8 on 42lb injectors in '06. My only "cooling" mod was a CAI.
Old Nov 6, 2013 | 12:06 PM
i944scania's Avatar
You could run 60s with a 2.9 and no cooling mods. Any smaller than a 2.9 and you need better cooling. Even with a 2.9, too much abuse would cause nasty iats. And yes you need new injectors..
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 30, 2015 07:22 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
