Forced Induction Turbos/Superchargers
Question About 2.2 S/C
Old Oct 20, 2005 | 03:43 PM
06LSCobalt's Avatar
I have seen alot about the S/C coming for the 2.2.. I am going to be buying a LS Nov. 18 (i hope if all goes right) What i am wondering is on the 2.0 it is a intercooled S/C will this be the same for the 2.2? Or will there be no I/C and the 3000$ or so is only including the S/C? Thanks for any Answers
Old Oct 20, 2005 | 08:20 PM
Halfcent's Avatar
I'm old school
Check this out:
http://www.gm.com/company/gmtunersou...k_to_250hp.pdf
Its everything I know about the SC for the 2.2L. I comes with an entirely new intake manifold with coolant ports and radiator hoses, so yes you are intercooled. Well, intercooled isn't the right word, but you know what I mean.
Old Oct 20, 2005 | 08:40 PM
zinner's Avatar
Moderator Alumni
The 2.2 S/C kit is not intercooled. We saw the prototpye at the GM small car bash. It's also an M45 not the M62. Your looking at 175 HP with it installed on the 2.2.
Old Oct 20, 2005 | 08:56 PM
wikkymaster's Avatar
^that cant be right, cav's with the eco supercharger are pushing a lot more than that
Old Oct 20, 2005 | 09:49 PM
Cobalt_Supercharged's Avatar
Originally Posted by halfcent
Check this out:
Look at this link to the ECOTEC build book. They say 250hp. They also show and talk about an intercooler.
Old Oct 20, 2005 | 11:51 PM
Halfcent's Avatar
I'm old school
Zinner might have more accurate data. The build book instructions are a reprint directly from the Cavalier / Sunfire kit. The kit described in the build book could not actually be used on a Cobalt. The kit in development for the Cobalt will be different. Also, just because it's covered under the 250HP section of the book doesn't mean that the kit produces that much power. It's just covering upgrades that produce up to 250. I would think that kit probably makes around 200HP.
As for the upcoming kit for the Cobalt, I can't imagine that it is much different. If the prototype that Zinner saw is the final production model, then his data would be accurate. You wouldn't have to intercool a smaller supercharger that only produces 175HP. But if they go with the M62, then I have to believe that it would include the intercooled intake manifold.
Old Oct 20, 2005 | 11:55 PM
I didn't realize that was for the old ECOTEC motors.
EDIT Wait, why does it show a cobalt in the pic, and didn't the last model year cav's have the same 2.2L?
Old Oct 21, 2005 | 07:31 PM
Halfcent's Avatar
I'm old school
It shows a pic of the Cobalt only because it is the current production car that uses the ECOTEC in a way that tuners would probably modify. Its just a promo shot.
The 2002-2004 J-bodies used ecotecs, and that is what those instructions are for. Yes, its the same motor, but the kit is designed to the body as well. It simply wont fit the Cobalt. In addition, the Cobalt uses an electronic throttle body, no throttle cable. That kit is for a car with a throttle cable, so thats another reason why it wouldn't work.
Old Oct 24, 2005 | 08:11 PM
zinner's Avatar
Moderator Alumni
Thats what the GM reps told Jonel and I. Sorry I didn't get any pictures of it
Old Oct 25, 2005 | 01:05 AM
redd214's Avatar
just do what i did get a wrecked ss engine and rip the s/c off.
as far as i know only one eco powered has the ss s/c installed. he pulled 218 hp, 202ft/lbs, on about 10 psi. everything else is stock besides his tuning with the e manage. i cant wait to see how the 2.2 w/10:1 compression ration reacts to the s/c with some breathing mods. its gonna be a fun winter.
Old Oct 29, 2005 | 03:54 PM
WopOnTour's Avatar
In the soon to be released GM M62 supercharger kit for the 2.2 the charge air cooler (CAC) is only partially supported. You HAVE the intake mounted Laminova exchangers, but if you look at the install instructions, the inlet/outlet lines are just plugged so techncially NO INTERCOOLER!
However if you add an electric pump, CAC radiator, hoses and reservior- you will basically have the same CAC system as the LSJ.
Here's a link to a short video of the LSJ Charge Air Cooler system
http://www.xau.net/video/CAC_VID.wmv
*Thanks to XAU for hosting it
PS> You MAY have to copy/paste the link above into your browser as XUA has re-direct blocking ON
HTH
WOT
Old Oct 29, 2005 | 03:58 PM
HTH
WOT
Says unable to access.
Old Oct 29, 2005 | 04:58 PM
WopOnTour's Avatar
I jut checked it and it works fine for me
You may need to copy/paste the link into your browser for it to work
WOT
Old Nov 11, 2005 | 02:22 AM
Kahless's Avatar
also depends on the price. if you can get a crate lsj for 3800$ id only pay about half that for an sc kit since youre gonna need to get new rods n pistons if you want the motor to live a happy life.
brandon04
Oct 21, 2015 07:04 AM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
Extremespeed
Sep 29, 2015 04:34 AM
