Forced Induction Turbos/Superchargers
question concerning bov
Old Jun 21, 2008 | 01:40 PM
mike25's Avatar
well i got my bov in and its an 11psi spring in it...tial 50mm...i plan to run my setup at about 10 psi or so...wouldnt i need a spring lower than the 10psi? only makes sense that the spring wouldnt ever compress on the bov because there isnt enough pressure...any takes?
bump anyone?
Old Jun 21, 2008 | 02:05 PM
BlackSS/SC's Avatar
The spring has nothing to do with the boost it will hold, well to a point. I've run 25psi+ and I have a Tial and use the -9psi spring. You are suppose to choose the spring according to your engine vacuum at idle.
Old Jun 21, 2008 | 02:18 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
True that.
Old Jun 21, 2008 | 07:16 PM
Sw4y1313's Avatar
Tial has a chart. if you idle at say -20 vac then you want X spring. I believe there are 4 different spring types to choose from. Its real simple as long as you know your idle vac.
Old Jun 21, 2008 | 07:20 PM
06blackg85ss's Avatar
cobalt you should use the 9 lb spring
Old Jun 21, 2008 | 08:09 PM
Jn2's Avatar
Jn2
arent the spring pressure adjustable thru the screw on the top? or it the tial not adjustable?
Old Jun 21, 2008 | 10:55 PM
mike25's Avatar
well initially thats what it thought...and ive noticed at idle i stay between 20-23 or so
Old Jun 22, 2008 | 09:01 AM
hmmm my car is only at =10psi/ are you read -HG or -Psi
Old Jun 22, 2008 | 05:43 PM
mike25's Avatar
well do you have to read hg when its stock or turboed? i wouldnt think it would matter, and according to tial's spec sheet i should be running a 12psi...the car stays around 21 or so
Old Jul 11, 2008 | 02:17 PM
IonNinja's Avatar
choose the correct spring according to vacuum and then go up or down depending on whether you get compressor surge or not
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
