Forced Induction Turbos/Superchargers
quick turbo question.
Old Apr 14, 2009 | 10:48 PM
ilovecars's Avatar
give me a minute so i can calculate the essential "perfect" turbo for your set-up. whats you power goal?
200 at the wheels.
approx give or take 15
Old Apr 14, 2009 | 11:01 PM
mike25's Avatar
Originally Posted by ilovecars
yes indeed. so to compensate a little would the lease amount of charge piping possible for the smaller turbo help at all? or is that a totaly differnt thing
in a sense yes smaller piping would allow that...but safest bet is 2.5"
Old Apr 14, 2009 | 11:02 PM
ilovecars's Avatar
hmmm. mkay.
Old Apr 14, 2009 | 11:11 PM
BLAZIN07SS's Avatar
I'm too JDM for you
on 12 psi of boost. your mass flow rate at the mid range is 14.49 lb/hr. at top end your flow rate is 28.97 lb/hr. your pressure ratio is 1.82PR. i am looking at different compressor maps now as to what would fit your needs the best
Old Apr 14, 2009 | 11:14 PM
Greased's Avatar
You may also want to learn the difference between a roots type super charger and the way turbos make psi
superchargers basically stacks air ontop of itself in the intake manifold because the blower moves more air per cycle than the engine can injest thus the excess air creates positive pressure in the intake manifold
turbos on the other hand are different, they suck air in and to put it in simple terms throw air at a wall (compressor housing) and it compresses itself and then is pushed out through the turbine outlet
Old Apr 14, 2009 | 11:17 PM
ilovecars's Avatar
lol look at the t25 dsm turbo.
oh yea i know that. lol that parts easy.
Old Apr 14, 2009 | 11:29 PM
BLAZIN07SS's Avatar
I'm too JDM for you
too small, you would be overspinning it and taking it out of its efficiency range
Old Apr 14, 2009 | 11:30 PM
ilovecars's Avatar
naw i think id be just fine boost range is about 2-5.5
Old Apr 14, 2009 | 11:36 PM
BLAZIN07SS's Avatar
I'm too JDM for you
i just read the compressor maps dude. with your corrected flow rates, your gonna be in the "sweet spot" right before mid range and at high end your going to be overspinning it. you want your mid range lb/hr to be just after the surge line on the compressor map
Old Apr 14, 2009 | 11:39 PM
ilovecars's Avatar
but but but. i have a good deal on one. i cant use it? i know it wont be perfect but it will do the job.
and do you have AIM so we can talk more directly.
Old Apr 14, 2009 | 11:41 PM
  #36
BLAZIN07SS's Avatar
I'm too JDM for you
it'll do the job. if anything later on im sure they have a big wheel upgrade for it
Old Apr 14, 2009 | 11:42 PM
  #37
ilovecars's Avatar
ic piping diameter has something to do with it. but remember turbo's operate off of exhaust volume. learn how to read compressor maps. they will be your friend. lol
i sorta know how to read em.
they do lol.
Old Apr 15, 2009 | 10:52 AM
  #38
mike25's Avatar
glad to see you got it all figured out. anymore questions feel free to ask
Supercharged06SS
Dec 11, 2022 04:47 PM
patooyee
Oct 15, 2015 05:11 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
maliki778
Oct 1, 2015 07:39 PM
Bohb
Sep 27, 2015 09:11 PM
