Ram Air hood?
Does anyone think it would be possible to make a functional ram air hood?
I was looking around my engine bay the other day, and it looks like it wouldn't be possible due to the location of the air intake.
The hood inlet would have to be off to the right, and that would just look dumb I think.
I won't be getting a ram air hood if it isn't functional...
Who reserected this ancient post, anyway?
Many people have mentioned the ram air hood as a "power adder"
front facing scoops only work in terms of cold air until you hit about 200mph
then they "ram air" on a n/a - sc I'm not sure
it's the "cool factor" 'cause I got a scoop so look out - that drives purchases
as mentioned in an earlier post - "cowl induction" style will yield better gains
high pressure on windshield
low pressure at scoop entrance
reversion
the "big boys" use them at the drags for a reason
reversion
1. Ram Air reduces intake air temperature, which cools the intake manifold. Cooler engine=More Power The cold air is also denser, creating a higher pressure inside the intake compared to the engine compartment.
2. Ram Air also increases intake velocity. Now this effect works better on carbureted engines, the venturies inside the carb further to speed up and increase density. The Ram Air grabs outside non-turbulent air, which is important on the intake side of an engine in that it allows the air to travel faster. A higher air velocity allows the air to reach the combustion chamber faster. Now once the air gets to the engine heads, it makes no real difference because the engine head already creates its own vacuum. And that vacuum is greater than any velocity of air that can be "rammed" until the vehicle reaches a supersonic speed. The compression of the air does not begin at 200mph, but more like 500-550mph.
Now if you could make a hood with large intake surface area, and narrow the channel into the throttle body, then you would be making somewhat of a ventury also.
Normal speed air with normal volume is traveling in a straight line. When you narrow the channel to the throttle body, that air that was just grabbed is being pushed from behind by more air. The normal air now has to travel down a narrower (less volume) space. The smaller volume possible forces the air to compress air. Compressed air is colder, and a cold air intake charge is equal to more air, which allows more fuel, which ultimately means more power.
Sorry for the long explanation, I took several aerospace science classes.
Cliff Notes: Ram Air does work. Intakes colder, less turbulent, outside air.
Cold air=denser air, Air + Fuel=combustion, 2(air)+fuel= better combustion, 2(air)+2(fuel)=best combustion
Actually Ram Air does work in two ways.
for turbocharged and supercharged vehicles? reason why im asking is because they both compress air and the only advantage i can think of would be if the ram air provided colder air then a normal intake but alot of peeps have a cai so...
Reason why im lookign to find out is because im very interested in a ram air hood intake but honestly hoods run like ~700 and building a custom intake to make it usable would require time (not exactly bad but im looking at the whole picture) Now the hood looks better which is a plus but i want it to add to preformance because i can better spend that money/time on something else that adds both looks and preformance and have it alot more "custom" if the ram air would only add a hp or 2 (i already have a cai)
Ram-air on forced induction cars don't do that much. It does help bring down IAT's but the air still needs to pass the blower/turbo and then to the heat exchanger/intercooler and then into the TB. You're better off improving cooling in the intercooler system rather than intake air.
On a side note. I had a flex tube running from my foglight hole when I evicted my useless foglights to my stock airbox with K&N panel filter. I didn't notice much HP gain at all. It was negligible on day to day street driving but on the highway with the ram air effect at its fullest. I maybe noticed slightly better throttle response and maybe a 1.234355 HP gain. I didn't get a chance to datalog the car's IAT's but some ppl have documented the same setup I had on my car and datalogs show slightly lower temps but not much to increase noticable HP.
About WRX and STi's topmount IC's...yes its ghey to have a intercooler on top of the engine. But at least its not as bad as the Mazdaspeed 3/6's where all they have is an air channel running under the hood that leads to the topmount. At least with the hoodscoop u can draw in cool air. On cold nights the IC actually gets pretty cool/cold depending on outside temps. The IC does get heatsoaked on hot ass days and after several hard full boost runs. Most ppl run turbo insulating blankets and misc. heatshields to help fight heatsoak. Ppl also resort to water sprayers and CO2 sprayers. Realistically, water sprayers are also iffy. they do sorta work if you can get the water droplets to atomize to actually draw away heat. What I did with my DIY sprayer was locate the water tank in the trunk with insulate and have a bag of ice you get from the gas station and run a mix of water. On a 28 deg Celcius summer day with ice water being sprayed for awhile and after a nice drive, the IC was cool to the touch. Buuuut. FMIC is best for cooling air...that's what I went with....
Cheers,
Cheers,
Which is now providing ram air to a turbo!
https://www.cobaltss.net/forums/forced-induction-50/alpine-2-4-auto-turbo-sneak-peek-55988/
And to answer the question about Ram Air on a supercharger or turbocharger, it will help to get cold air, but the ram effect isn't very noticeable.
Now if you had a tunnel ram intake (n/a), with Ram Air that would amplify the effect, and you would see almost tripple the power gain.
Except your intercooler on the WRX sit on top of a hot engine. And heat rises. I think most WRX owners who do a lot of work on their car make a front mount intercooler one of the items to upgrade. I think the top/hood mounted intercool looks cool and keeps the intercooler safe from rocks/road hazards (rally heritage)
In my opinion though, i'd just go top mount for a WRX/STi. Yeah the intercooler heats up b/c of the rising motor heat, but the air your sucking in is still cold and dosen't have to go through any heated pipes, so it'll still be cold when it reaches the motor. Plus, while some think the complex array of pipes under the hood of a WRX/STi with a front mount intercooler looks cool.......I just think it looks cluttered.
This what you had in mind? I want this in carbon fiber http://www.suncoastcreations.com/Pho...%20Gallery.htm
ya id probably say that that doesnt increase performance but rather decreases it. that setup would work great on a n/a car because it forces air into the intake causing the engine to breath better... but on a supercharged car thats what the supercharger does and unless the supercharger cant get air (a simple cai would be more then enough) adding extra air on the intake side doesnt really work so it would equal out with a cai BUT the short ram is going to be getting hotter air because its in the engine bay so performance may decrease becuase of that simple fact
http://tntautosport.com/index.php?ma...roducts_id=157
The Suncoast Creations hood is a true functional ram air hood with the hood scoop going into tunnels underneath the hood (not just dumping onto the engine or into the engine bay), it actualy exits on the right side (if your looking at the front) and also has a air filter settup which sits right where the exit port is.
