Forced Induction Turbos/Superchargers
removing the oil pan??
Old Aug 1, 2011 | 09:00 PM
killswitch1209's Avatar
ok i have don everything i need to do to turbo my car i installed everything but i cant get the oil pan off to make a drain fitting for the turbo i have all the bolts out and its still really well sealed anyone have any tricks to get this off its a BI***!!!!! please help
Old Aug 1, 2011 | 09:03 PM
startingline05's Avatar
i really dont know if this is what your really suppose to do but it worked for me. i took out my oil dip stick. wrapped a cloth around a pry bar and placed it where the dip stick went into the oil pan. then i took a hammer and hammered the **** out of it. afterwards i was able to go back underneath the car where the oil pan was nice and lose and took it right off.
Old Aug 1, 2011 | 09:06 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Make SURE all the bolts are out... like 110 percent. The two trans bolts... the bolt hidden up in the A/C mount point... etc.
There is a notch on the passenger side, between the pan and the block (iirc, there's another one somewhere else too)... stick a pry bar or STONG screwdriver in there and pry it off CAREFULLY... you don't want to break anything.
You DID drain the oil first, right?
I do not recommend this method.
Last edited by USMCFieldMP; Aug 1, 2011 at 09:06 PM. Reason: Automerged Doublepost
05Slowline's Avatar
I took a rubber mallet or w/e and tapped around it then took a crowbar and leveraged on the back of it and it popped off, if it's the first time off it's a real pita i'll tell ya that lmao but it's easy
Old Aug 1, 2011 | 09:08 PM
i tried the proper way first, just how you explained it. it was just a pain in the ass. my way works im just not responsible if something is broken haha
Old Aug 1, 2011 | 09:12 PM
Like I said... I don't recommend it. Not saying it doesn't work. Haha.
Old Aug 1, 2011 | 09:14 PM
lol his next thread will be titled: Broken oil pan need help!!
Old Aug 1, 2011 | 09:18 PM
Exactly.
Old Aug 1, 2011 | 11:21 PM
ya ill get it no problem everything els was cake
Old Aug 1, 2011 | 11:27 PM
Omnigear's Avatar
passenger front corner you left 1
Old Aug 1, 2011 | 11:35 PM
That's the one I was thinking of too.
Just above that is the notch to remove the pan.
Old Aug 1, 2011 | 11:42 PM
Omnigear's Avatar
OP if you cant find it , its above the subframe ^_^
hope you haz skinny fingahs
Old Aug 2, 2011 | 12:06 AM
You have to take out the lower A/C bolt, as well... iirc.
Old Aug 2, 2011 | 12:54 AM
Omnigear's Avatar
^this
Old Aug 2, 2011 | 06:12 AM
05Slowline's Avatar
4 bolts must use open end
Old Aug 2, 2011 | 08:32 AM
Ryan@zzp's Avatar
8lb sledge hammer, I kid, I kid! Let see Pic's of the setup.
biniecki
Oct 25, 2015 02:23 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
