Forced Induction Turbos/Superchargers
s/c pressure
Old Jun 6, 2008 | 03:34 PM
Blk06SSTexMan's Avatar
s/c pressure
when i first got my car, at idle the pressure would be around -22.5 to -25 psig. recently, at idle, my car sits at maybe -17.5 psig. i try to drive soft with my car, not really push it hard in traffic to save on gas. any ideas what would cause this?
Old Jun 6, 2008 | 03:35 PM
invisible's Avatar
Maybe cause it has warmed up and it's almost summer.
Old Jun 10, 2008 | 04:08 PM
i guess. i'm still getting used to my car, so i'm still noticing little things about my car
Old Jun 10, 2008 | 04:09 PM
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
boost/vacuum leak
Mine rides at -20 psig on the highway staying off the gas.
Old Jun 10, 2008 | 04:11 PM
Drakonen2000's Avatar
mine is at about -20 at idle and we have about the same temps....but its wayyyy more humid down there!!! it could be weather, or it could be a small vaccume leak...but with a supercharged system im sure a vaccume leak would be apparent in other ways too
Old Jun 10, 2008 | 04:32 PM
lewisb13's Avatar
Are you able to hit full boost?
Old Jun 11, 2008 | 05:42 PM
well, last time i checked i could, but that was before i noticed this... i might have to test that out
Old Jun 29, 2008 | 07:15 PM
06SS/SC's Avatar
What is the problem if he can't hit full boost? Right now I'm having a problem--I'm only hitting 5 psi and the S/C sounds like it is struggling to get air to produce more boost. I've already cleaned the MAF and the Throttle Body, looked at every hose and connection. Can anyone help with this problem??
Old Jun 30, 2008 | 10:34 AM
blacksssc06's Avatar
check the superchager gasket or the intake manfoild gasket if not sound like a problem with the wastegate or if you going full out the belt might be slipping
GaryGibblez
Jan 14, 2020 10:35 AM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
bucks121
Sep 12, 2015 07:39 PM
