Sc+tc
Sc+tc
I know this sounds crazy but what about a turbo running into a supercharger ? I mean this could work right? Yes it would require large amounts of fuel and most likely alot of internal upgrades and tuning but has anyone else dreamed about this? Only problem I see is cooling the air from the turbo and the air from the supercharger .. Meth injection would most likely be a must.
No. Just plain no. There is twin charging but it's S/C power at low rev's to spool up the turbo then once at full spool the turbo takes over and the S/C is just another thing spinning with the drive belt. Properly sized turbo is much more cost effective and will produce much more power safer than a twincharge or any configuration! This has been beat to death Why no search button used?
wow ....you might as well light money on fire .....it CAN work zzp has done it ...but its not gonna be beneficial the biggest problem with cobalts is making traction not power.....that thing would have to be detuned to make any usable power
if you have that much money (WHICH I SErIOUSLY DOUBT)....you should go turbo with a mild cam....
