Forced Induction Turbos/Superchargers
spraying meth after the supercharger
Old Dec 29, 2008 | 02:58 PM
ebristol's Avatar
Originally Posted by 383_Stroker
Not to argue, but this statement suprized me a bit. Really!?
Meth is the only cooling mod I have and my IAT2s don't get above 140 even after multiple back to back pulls.
Well if he is being specific spraying meth does not literaly lower IAT2s temps. Example, if you are driving and your IAT2s are 95 degrees and you slam on the gas which starts your meth spray your IAT2s are not going to drop to 80 degrees. But the meth will control the IAT2s much better as boost builds into the higher rpms.
So I am not really sure what he is trying to say exactly.
Edit:
Just for those who may not have seen this...
Originally Posted by AIS
Yes, I have some experience with spraying after the supercharger with the 03-04 Ford Cobra's which are essentially very similiar to the Cobalts in the sense that they come equipped with the larger Eaton M112 supercharger and are also equipped with an air to water intercooler.
Give me a call directly at 801.447.2559 if you would like to discuss this in detail. In short, while it did have some slight advantages in some area's but in the end it ultimately did not perform any better performances wise then spraying before the unit. Matter of fact, there are considerable advantages to spraying before the supercharger. Give me a call if you would like to discuss this in more detail.
Rodney
Old Dec 29, 2008 | 04:08 PM
Steven Flit's Avatar
140* iat2 on a 2.85 pulley is nothing to brag about.
w/o meth I see 100* iat2 on dual pass, option b and cobra h/e w/ a 2.7 pulley.
3rd gear WOT @ 5500 RPM 88 mph w/ an outside temp. of 50* F.
Again, meth before the blower will not lower iat2s.
Old Dec 29, 2008 | 06:06 PM
HunterKiller89's Avatar
incorrect sir. think of it like a chem class. The water/meth is removing heat, whether it removes it from the SC or from the IM will play a factor, but heres the thing: spraying into the IM will cool the charge air directly after it has been heated up. This will cool IAT2's
Spraying before the SC will remove heat from the SC and probably a little from the air charge/IM as well, though not as much. This will lead to a cooler blower, causing the IAT1 air to not heat up as much, leading to a cooler IAT2
One method cools a very hot IAT2, whereas the other method is better at preventing the charge from ever seeing high IAT2s
to put numbers on it, say your IAT1 is 80*. If you spray meth into the IM, the 80* air may heat up to 150* air, then drop back down to 110* air when it hits the meth in the IM.
if you spray before the SC though, IAT1 is still at 80*. The air then will only get heated to say 120* before it hits the IM, since the water/meth is already mixed with the incoming air.
get it
Old Dec 29, 2008 | 08:37 PM
Jrhdpaintball's Avatar
Originally Posted by ebristol
What about the Laminova cores? Just because you are spraying after the SC doesn't mean the mixture is going directly into the head. The mixture will still have to pass through the Laminova cores which, if your theory is correct, would dissapate all the meth too.
So I think your theory is a little flawed. The only way to get the meth/water mixture into the head as you describe would be use a IM to head spacer plate like this.
Get 4 1gph nozzels and spray directly into each intake port.
That is not true. I have logs to show that not only do the temps drop but they also stay cooler much longer then with out meth.
first, where did you get that spacer...is it made and how much... id love to do some work with spraying into each runner..
both of your guys theorys seem to make since to me...hunters theory really is just trying to prevent some of the heat from happening buy lowering it before it gets that hot... while bristols theory seems to be the most effective...regardless of what ever the temp is at the SC bottom line is, before that air gets inside the engine...its cooled.... cooled at the end of its path, with less chance to heat up any further
just what i am gathering from all this...
so why not spray before the sc to cool the charge leaving it, and cool it again before it gets to the engine... would there really be any disadvantage to spraying both... besides using more meth?
Old Dec 29, 2008 | 09:14 PM
^^ nope. as long as you dont spray so much meth the engine cant take it...lol but that would be a LOT of meth. Hook up 2 different 2gph nozzles and see what happens. im sure you'll love it
Old Dec 29, 2008 | 09:26 PM
i cant wait... ive got a single pass manifold now.. and its very differant from the stock endplate quad pass... seems to be a good cooling mod right now, just waiting on my new front mount... im going from a cobra he. to the big cx racing h/e...ive got a slight leak from my cobra, and want a bigger one anyway...
really just trying to go along with ralliartists ideas of cooling mods up the ass, then tack on some power mods... even tho some argue that meth isnt a cooling mod but you know what i mean
as soon as i get this all set up, im really just about done i think, atleast for the summer, then during the summer ill be purchasing everything needed to change pistons, oversized valves, springs, prolly keep the same cam, and clutch...
but that will be next winters project lol, luckily ive got a spare engine from my previous one, that will cut down on down time
Old Dec 29, 2008 | 09:43 PM
ebristol's Avatar
The spacer is old school and was used to tune LSJs before HPTs was available. Basically, the car's ecu runs stock and a piggy back tuning systems runs the additional 4 injectors. It was used in the first twincharged ION Redline.
While this kit was being developed HPTs released its support for the LSJ and pretty much killed the development of this product. As far as I know it is one of a kind.
I don't know if there are any disadvantages to spraying before AND after the SC other then unnecessary complexity.
I was thinking......about removing the fuel injectors from the spacer plate and having the holes tapped for meth nozzles. I could run a 1gph nozzle in each hole for a total of 4gph directly into the head. Then run a 2gph nozzle before the SC or a grand total of 6gph. I am running a 5gph nozzel right now into a TB spacer.
But who knows if it is actually worth it. 5 new meth nozzles is not cheap.
Old Dec 29, 2008 | 09:48 PM
383_Stroker's Avatar
Well, that's cool.. I wasn't saying that I had the coldest IAT2s on the board.. just that they were better than they would be without the methanol...
Old Dec 29, 2008 | 09:53 PM
wos lol does sound oldschool.. im going to make a few calls to friend of mine in a machine shop, bring him my spare IM and see if he can mkae a 1/2 thick spacer just like that... if so that would be crazy...
would tuning for spraying in the runners also spraying before the sc... be simular to just spraying before the sc?... tuning it is totally out of my area of knowledge... id LOVE to learn all the tricks about it... but dont even know where to start
also, my IATs are looking like right now... iat1 roughly have been around 40-45*... iat2 have been no higher than 75*-85* crusing at about 60 mph....with a WOT pull im hitting around 95*-100* put quickly drops back down... the only thing that kinda gets me stumped is how i can be driving with iat2 around 75*, let off the gas and slow down, and then they will shoot up to about 85*, then speed up about 15 mph...then they drop again to 75*
the set up seems to flucuate alot more than i remembered with just the stock endplat
Old Dec 29, 2008 | 11:00 PM
i am going to guess that this is caused by a hot intake manifold. If the intake manifold is hot, and your hard on the gas, a lot of air is flowing through it at a very fast rate, so the heat doesnt have a lot of time to transfer from the manifold to the air. If you lessen on the throttle though, there is less air moving at a slower rate, so the heat can transfer from the manifold to the air a lot better, making a hotter IAT2. This is just a guess, but it seems like the most logical thing to be happening to me.
he's just excited he has cool temps. he's been flaunting his numbers to me for a couple days now
you know steve, my numbers could be even cooler. I just need an IAT2 sensor
Old Dec 29, 2008 | 11:20 PM
  #36
HOT CARLS SS's Avatar
Well I have one of RAW's meth inj. kits and I have it spraying after the blower with a spacer plate between the blower/intake. It has a square hole opening and 2 nozzles spraying into the air stream....it lowers my IAT2's about 30-35 degrees that was with a 2.7 60lbs injectors , no HE and No option B. Over all a nice kit with no problems for 2 yrs or so...I run mild timing advance about 24 degrees up top at the most...just preference.
Old Dec 30, 2008 | 03:12 AM
  #37
ehm... giant pulley...
I'm more curious as to why your seeing such high temperatures on a 2.85 pulley w/ METHONAL.
get it
You make a great point
But, spinning a 2.7 or smaller pulley and spraying before the supercharger, will not yield as good of a cooling effect on IAT2. The blower is made to run hot, let it be hot. You guys need to focus on what the most important thing is, and take care of it.
For those running larger pullies, the upgraded intercooler system are more than substantial, and do not create nearly as much heat as a 2.7 or smaller pulley. In that case, spraying before the blower may be beneficial, to help aid our struggling laminova cores cooling the hot air from the eaton m62. Though, to see better results you will need to spray into the intake manifold.
Last edited by Steven Flit; Dec 30, 2008 at 03:16 AM. Reason: Automerged Doublepost
Old Dec 30, 2008 | 03:38 AM
  #38
giant? its only a 2.9! lol. your a whole 1/5th an inch smaller than me!! haha
Old Dec 30, 2008 | 03:45 AM
  #39
And spining o so much faster!
Old Dec 30, 2008 | 08:43 AM
  #40
Well, as I said, that was after multiple pulls.. .. By multiple I mean 6 or 7 runs. Each running through 3rd, doing a u-turn and coming back.. (Trying to replicate a intermitent miss.. and, of course, couldn't make it do it when I was trying to log numbers )
Jan 12, 2016 12:01 AM
dennis69
Oct 20, 2015 04:49 PM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
