Forced Induction Turbos/Superchargers
Superturbo
Old Jun 24, 2006 | 12:24 AM
  #51
NJHK's Avatar
Originally Posted by JMAc88
what trim would you need to support 500+ hp? you would still need a rather large one, and with that large trim comes the lag. 3500 RPM in rality is not that long, its maybe a half a second when your driving. But when you at the track a half a second could be half a car lenght and the drifference between winning and losing. That might sound cheesy but i hate to lose.
Also, the difference in price between going all turbo and twincharge would be minimal. Both set ups would require all the basics, lines, pipes, ect, the turbo, intercooer all the goodies, but with turbo you will have to either a) gut the s/c to act as an intake manifold (popualar option with the cobra guys) or b) get an actual intake manifold. So if the cost is going to be the same, why not twincharged?
Also by the way, if i DO decide to go twincharge, it will be a custom job, and not some prefabed hahn kit that will push out minimal power.
Well if you're aiming for 500 HP, I'd hope to god that you're doing motor work. If you're doing your valvetrain system correctly, you can spool a bigger turbo. I've done that and I will say that I have no problems spooling a T3/T4 50 Trim.
If spooling is still your issue, that's why there are ball bearing turbos.
People are still missing the point of twincharging...your supercharger is being your restrictor. You throwing boost from a turbo to your supercharger will only do so much but it won't increase your boost levels because your supercharger is still dependant of your crankshaft and will only spin at a certain rate of speed.
Gutting a supercharger is not twincharging...you just took out the internals of the supercharger...so it's not "charging" anything, it's basically sitting there as an alluminum intake. Anyone who is only twin charging because they are too lazy to take off their supercharger, shouldn't be boosting (in my opinion). If you take the supercharger off, you could sell it and make an actual profit rather than have it sit there and take away power that you're aiming for.
Old Jun 24, 2006 | 01:24 AM
  #52
JMAc88's Avatar
There was a study done on a twincharged subbie, about how the turbo compresses the air and then the S/c compresses it further resulting it the same amount of boost or something along that line. I will see if i can find the artical.
Old Jun 24, 2006 | 02:16 AM
  #53
JMAc88's Avatar
Also, when i said gut the S/C it was meant for a turbo option, not a twincharge option. The reason it is a popular option on the cobras is because the have a similar heat exchanger set up. So you could run both and intercooler and still have the exchanger setup.
Old Jun 24, 2006 | 02:22 AM
  #54
NJHK's Avatar
Understood.
Old Jun 25, 2006 | 11:23 PM
  #55
SpecialK's Avatar
The point of twincharging is to run a huge ass turbo with no lag, something like a 76 trim. Its not to get more horsepower or anything like that. Its to achive your power at a faster rate. By buddies 2.2eco with a 65 trim T3/T4 hybrid only fully spools at 3500-3750RPM, thats half your gear right there. Think of how long a 2.0L engine would take to fully spool a T4 76 trim turbo. Now imagine spinning that T4 76 trim with no lag what so ever, feels good right. Thats what twincharging is about.
As for Josh, he should have done it the right way and build his engine. He tried twincharging a stock LD9 (not gm's greatest motor) what else do you expect. It wasn't because it was twinchaged, he was just pushing crazy amounts of boost into an unbuild enigne. Would have happend whether it was twincharged or just turboed.
Precicely why twincharging is so popular. Min lag/ boost building. WOth the S/C forcing air past the intake turbine you effectively are forcing the turbo to spin faster. Kinda like blowing on a pinwheel to put it in perspective. I personally woudl never twincharge a car. Its' too complex as I said earlier. And yes a better alternative is honestly a good turbo setup. But having a oversized turbo also brings in another perk, a pancake flat torque curve that goes damn near to redline. Making for one FUN setup.
SCC made a 300WHP SCT focus and used a T3/T4 I believe. Running all of 12lbs of boost the turbo hit full boost at 4500rpms and the torque peak was there, and held till a few hundred short of the rev limiter. RUnning an oversized turbo has it perks and it's drawbacks.
Me personally, I'm gonna go with two IHI RX6B turbos on my T/A. Once I get the rotating assembly bought and the engine prepped.
Old Jun 26, 2006 | 01:54 AM
  #56
NJHK's Avatar
I agree with what you're saying but that part doesn't make sense to me or maybe you're not putting it in good context. When you say "past the intake turbine" what do you mean?
Old Jun 26, 2006 | 11:23 PM
  #57
SpecialK's Avatar
IN other words you are force feeding the intake side of the turbo wiht high velocity air. Think of it as paralell twin turbos. Only the first can bring boost to 1psi just off idle.
Old Jun 27, 2006 | 09:39 AM
  #58
AlbertanCobalt's Avatar
In the natural gas industry multiple stages are used all the time. Often the methane (air or methane, gasses act the same) is put through 3 or 4 stages of compression to allow it to be transported. The higher the inlet pressure into the second stage the less work required to bump up the pressure higher. In 3 or 4 stages these compressors can take an inlet pressure of 5 psi to a line pressure of 850 psi. So it does work, even if on a massive scale.
There are always coolers in between stages so that they aren't compressing a hot gas. So placing an intercooler (which is actually where an intercooler can only be, for an 'intercooler' after only 1 stage (a single turbo or supercharger) is actually an aftercooler) in between stages is a way to keep intake temps down and allow for higher boost.
If you are blowing past or into your second stage with no suction, why would you need a second stage? You would need the second stage to still be drawing (negative pressure) in the pressurized air in order to make more boost. If you are making more boost after your 1st stage and are just blowing on the second stage, you would loose boost to drag in the impeller.
A twincharger system would have to be matched in order to increase the boost, but done right it would work without a doubt.
Old Jun 27, 2006 | 07:09 PM
  #59
sheek360's Avatar
Originally Posted by SlateFox
twincharging doesnt really do anything. it wont add any more power trust me. i thought it would add more power but it doesnt. as for a show thing it would be kool. i used to work on trucks with the twincharging and it really didnt add much. it adds a bit of power but not too noticeable unless its on a diesel
theres a twincharged redline that posted his sick 330whp dyno! WTF are u talking about, stop giving bad advice or the individual that started this thread may stray from his original goal. from now on plz dont give out advice till u do some research, did i add he still isnt done with the tuning? 400whp is still in the works for him.
good day.
Old Jun 27, 2006 | 07:22 PM
  #60
Shortbus's Avatar
Originally Posted by Brian MP5T
It would be easier and cheaper to just trade in the cobalt and buy a 2006 WRX STI + a MBC.
Yea, evreyone just go out and buy a sti, no biggie, the point is to mod the cobalt, not to give up and just get a new car, i still ponder why your still here.
Old Jun 27, 2006 | 08:02 PM
  #61
sheek360's Avatar
LOL! Agree 110%! Awesome setup by the way, you dyno that beast yet?!?
Old Jun 27, 2006 | 10:56 PM
  #62
Shortbus's Avatar
[QUOTE=sheek360]LOL! Agree 110%! Awesome setup by the way, you dyno that beast yet?!?[/QUOTE
Thanks alot, no not yet, i hope to take it to the track sunday to see what it can do, hopefully i come back with some good numbers!
Old Jul 3, 2006 | 11:12 PM
  #63
SpecialK's Avatar
good day.
330whp huh? DO you have any links to this members dyno sheets? What's is this members name? Not callign BS just interested in hsi particular setup.
Old Jul 4, 2006 | 10:44 AM
  #64
sheek360's Avatar
cant link because of the forums rivalry with this one. go to the red line forums.com <had to space it or it wont come out, sorry> search for twincharged dyno chart.
I heard the system hahn is working on is about 400 horses! I would never buy from them but its still impressive!
Old Jul 5, 2006 | 12:40 AM
  #65
SpecialK's Avatar
Heh, imagine that a different forum with a bit of sand in their **** between both of them. Well least it isn't Honda Hookup or somthing. Heh, still remember when I was actually allowed on there. "Can anyone give me vids of their car posting a time faster than mine? No? *Gets banned*" LMAO.
Well I did look and I can say for sure that's a mickey mouse setup if I ever saw one. Still, it works.
Old Jul 5, 2006 | 07:53 PM
  #66
sheek360's Avatar
preety neat huh? intimidating to say the least. seems like a pain to tune too
Old Nov 24, 2007 | 02:09 AM
  #67
Preowner's Avatar
The physics side of my brain says your taking the power adding of the turbo and subtracting the efficiency loss of the SC from it; netting a smaller amount of power than with just turbo. Then the gullible side of me totally understands the "compress then stack" theory. It would be real interesting to see two things
1) Gauge the boost coming off the turbo, but leave the stock gauge in to show the "total" boost. Were it a true "compress then stack" or any sort of two stage compression situation I would think there should be a decent difference.
2) Gut the SC Leaving everything else the same.
Not failing outright doesn't necessarily mean it isn't flawed science.
I'm being a devil's advocate to a certain degree. I don't mean to crap in anyones wheaties.
In the end I'm undecided on the theory
And sorry for raising a dead thread
Black 2.4 SS
Oct 12, 2012 09:38 PM
ilovecars
Apr 11, 2011 04:55 PM
glockglade
Dec 26, 2005 02:47 AM
glockglade
Nov 22, 2005 11:25 PM
