Forced Induction Turbos/Superchargers
surge and bov.
Old Apr 12, 2010 | 09:23 AM
rico's Avatar
surge and bov.
my bov sounds pretty good if i hit 10 psi or so. but lets say i get 3-5 psi and let go off the gas it sounds funny. kinda like fluttering or something i guess thats the well known bad surge? cheap bov? or need to open it more? or what? first time messing with this so I need some input/help
thx for any help in advance
Old Apr 12, 2010 | 09:30 AM
iboost's Avatar
sub'd
Old Apr 12, 2010 | 10:06 AM
busa4's Avatar
is the bov adjustable? if not, you will need a lighter spring.
Old Apr 12, 2010 | 10:15 AM
rico's Avatar
i beleive so i can rotate it both ways so ill say yep
Old Apr 12, 2010 | 10:16 AM
BYT*SS*TURBO's Avatar
Compressor surge
Old Apr 12, 2010 | 10:28 AM
rico's Avatar
how do i fix that problem?
Old Apr 12, 2010 | 10:30 AM
Loosen the BOV a lil
Old Apr 12, 2010 | 10:32 AM
rico's Avatar
will try that. thanks
Old Apr 12, 2010 | 03:10 PM
busa4's Avatar
since its adjustable. run your engine at idle and adjust the bov to were the bov slightly opens at idle vacuum. once you get it there then put a litte more tension on the bov spring to completely close the bov at idle. this will prevent the bov from opening at idle. the engine will produce more vacuum coming off the throttle under boost (as compared to idle vacuum) opening the bov.
Old Apr 12, 2010 | 08:58 PM
BlackCobalt707's Avatar
how about on a type h/rfl bov?
Old Apr 13, 2010 | 10:15 AM
busa4's Avatar
if its adjustable. follow same instructions. if its not then the spring will have to be replaced.
Old Apr 14, 2010 | 08:28 AM
rico's Avatar
eh my bov is weird ima get a new one once i get new pipes done
Old Apr 14, 2010 | 08:57 AM
Stiner's Avatar
Did you try what busa said? I'd try that before you switch parts
Old Apr 14, 2010 | 08:58 AM
rico's Avatar
yep. gonna check my line on the bov tho and all before anything
Old Apr 14, 2010 | 09:17 AM
Do you have just your BOV on that Vac line? Its always good practice to seperate the WG and BOV lines.
Old Apr 14, 2010 | 09:18 AM
rico's Avatar
no its t'd with a sensor .ima put it on its on. and i dont have WG this set up came internally gated lol
NJHK
Forced Induction
59
Aug 6, 2009 11:18 PM
kobaltking2589
Tuning
Jun 1, 2007 05:38 AM
redFLcobalt
May 29, 2007 06:46 PM
sleepercobaltsc
Apr 27, 2007 05:17 PM
Boosted_SS
Mar 19, 2007 09:56 PM
