Forced Induction Turbos/Superchargers
throttle body for supercharger
Old Mar 7, 2012 | 02:03 PM
Allgood Customs's Avatar
So I've been doing some research and am still confused. I'm getting a TVS blower and right now I upgraded my 2.2 tb to the 2.4 can I use either of these on the blower or do I need an LS4? Also if I do go with the 2.4 TB can I use 80 lb injectors since more air needs more fuel?
Old Mar 7, 2012 | 05:22 PM
Old Mar 7, 2012 | 11:51 PM
bluebalt07's Avatar
You can use any tb you want to but it's gonna be restrictive unless you run the LS4. The LSJ is the next best thing but is still gonna be smaller than the inlet on the TVS. You can run the 80# injectors regardless of what tb you run but you may be able to get away with 60's depending on which you choose and what pulley you run.
Old Mar 8, 2012 | 01:21 AM
so which tb is the LS4 like which engine? and I'm going 2.8 pulley is that ok with 80's
Old Mar 8, 2012 | 01:25 AM
SunburstSS's Avatar
There ya go, performance wise is the same from the research ive made before as far as different ls4 TB's, Its a good idea to get it ported and polished too to net more gains
Originally Posted by SprChrg4Life
Yo. Lookin to get tuned soon to fix my shitty canned tune, might as well finish the exhaust and get the LS4 TB so i only need one session. i found TWO different LS4 throttle bodies, can some1 help me make sure I get the right one?
Wiki'n the LS4 engine, it is a 5.3 V8 and it was in the '06-'09 Impala SS. However, I noticed TWO different part numbers when searching for this TB for my cobalt!
My dilemna; an 08-09 Impala SS (LS4) is AC Delco #217-3107 and GM #12631016. It is a "discontinued part #" due to Pontiac's bankruptcy, and is being sold for cheap @ rockauto!!
Whereas the 06-07 Impala SS (LS4 as well) TB, is AC Delco #217-2296 and GM #12568580 is $60 more on the same site. WTF? variying part #s on LS4 TBs. Depends on the year. When I loaded both from rockauto into the shopping cart, it said they both fit the '08 Grand Prix GXP. So... it is the same TB with different part #s?
My question is, did they make any changes to the TB and which one should I grab? seems they are both for the 5.3 LS4, I'm afraid of it not being plug-and-play with a different harness or whatnot... Guess I could always lie and say I have an '08 GXP and say it doesn't fit properly
Some1 let me know what year of the LS4, and for what car, the TB for our cobalts is from, I'd like to save $60 if I can that'll net me a free TB spacer and save me some dremel time!
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
