View Poll Results: Injen cai with future turbo plans?
Voters: 62. You may not vote on this poll
Turbo in 9 months
Originally Posted by sneaky
You can make a custom charge pipe to route to where the original pipe WOULD/SHOULD be and then use a CAI kit and mount it like as if the unit was right where it should be.
it is high bit it can be done with moderate boost on stage 1 at about 6 psi which with my setup should net me about 220 whp until i can do tranny and intenal and fuel mods it will work fine
Originally Posted by SSmoke
Correct me if i'm wrong but @ 10.4:1 compression ratio that's too high for F/I so you'll need a thicker head gasket to drop the ratio to 8 something...
It will scream though, High compression and mild boost is more powerfull, just easier to blow up...
well, i think i will be very happy with low boost and high compression for a while. it will be temporary only though since i cant boost higher than that even if i did lower compression becasue the transmission still needs reworked to handle more power so first i will get teh turbo kit and put that on with lots of tuning done before running hard, then i will work on the transmission then i will do internals...220 hp should be good for me for the time being while saving to do all those things
Is it an AUTO?
yes it is an auto just like gm's race cars are auto...
Wow, I don't know if it's just BS or if there is some truth to the matter, but I think Autos dont like HP without some serious work such as Cooling and Torque Converter upgrades..
there is truth to the matter, check up on gary gardella that races a red cobalt in the nopi x box cup hes one of the fastest cars on there and he uses an automatic, its true that auto need alot of work to be bulletproof in high hp applications and i plan on doing the work like half cent is doing for around $3500 which is worth it to have perfect shifts everytime i race and never worry about misshifting but the turbo will go on with the stock tranny at first and i will limit the tq to 200 pounds until the tranny gets reworked and the internals are done, its a long and expensive process but a fun one.
Great, I wasn't insulting, I was just concerned that it was not part of the original plan...
has anyone considered ordering a ready built tranny? I mean one thats rated for say 500HP to the wheels? I know there are trannys pre-built to these kinds of specs. I wanna know if I could fit a 4T65eHD under the hood of my bad boy
Most Stock Manual trannys can handle 400 with Clutch and driveshafts...
Originally Posted by Brian MP5T
Like "Stock Class Drag" or like A Tube Frame with the Skin of a Cobalt "Drag Car"
http://www.motorsport.com/news/artic...?ID=175795&FS=
http://www.gminsidenews.com/forums/s...d.php?p=257394
Yeah, Oh, not Built at all...
