Forced Induction Turbos/Superchargers
turbo build drawing
Old Apr 24, 2008 | 09:00 PM
Jn2's Avatar
Jn2
turbo build drawing
basic drawing on how i plan on routing the pipin for the turbo
^^^front
^^^passenger side view
^^^driver side view
^^^top view
now since nobody did anything to help exceptt say to search which i did b4 my thread, and after it, i decided to go out side, look at everything, look where i room to route the piping thru and came up with this basic sketch of it, i used MS paint, so any of the bends that are sharp will be mendrel , also the way i put the MAF and BOV, would that setup work? BOV closer to the TB, and MAF further, also on the piping after the Ic i found that theres is a small hole inbetween the lower radiatior hose i which i can route the pipe upwards...
Old Apr 24, 2008 | 09:07 PM
MadBrad's Avatar
Wow sombody has way to much time on their hand. LOL Are you sure that item #2 will not bump into anything coming up and over like that?
Old Apr 24, 2008 | 09:08 PM
mike25's Avatar
dude check out my build thread...youl see how it needs to be run
Old Apr 24, 2008 | 09:22 PM
rob561's Avatar
Do Not Put The Maf Before The Bov. You Do Not Want To Blowoff Metered Air!!!!!!!!!!!!!!!!!!!!!!
Old Apr 24, 2008 | 09:29 PM
Jn2's Avatar
Jn2
so which goes closer to the TB, the MAF or the BOV? also link to your build i have seen alot of build thread, and noen gave a adaquete discricption or picture of pipe routing
Old Apr 24, 2008 | 09:47 PM
mike25's Avatar
go the the advanced mods section and hit mike25's build thread....the maf goes closer to the tb....put the bov in the piping that goes from your turbo compressor to your intercooler
Old Apr 24, 2008 | 10:07 PM
Jn2's Avatar
Jn2
ok than, bov in the pipe from turbo->intercooler, got it, and maf on the cold side of the intercooler
Old Apr 25, 2008 | 10:42 AM
rob561's Avatar
the Bov can go anywhere between the turbo and the maf. so in order 1.turbo 2.bov 3. maf 4.tb
Old Apr 25, 2008 | 03:30 PM
Jn2's Avatar
Jn2
^^^thanks for the info, i ordered my intercooler yesterday, gunna go on ebay and order the piping kit for it right now...
Old Apr 25, 2008 | 06:26 PM
mike25's Avatar
what ic did u get
Old Apr 25, 2008 | 09:32 PM
Jn2's Avatar
Jn2
got the same one you did, but mine will say cobaltss.net across it
Old Apr 25, 2008 | 09:54 PM
mike25's Avatar
you going to custom spray it or is treadstone doing it for you?
Old Apr 25, 2008 | 10:29 PM
Jn2's Avatar
Jn2
im goign to custom spray it
also gunna sand/grind the end tanks and do the in metallic silver instead of the chrome look
Supercharged06SS
Dec 11, 2022 04:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
