Forced Induction Turbos/Superchargers
Turbo Build Questions
Old Mar 9, 2011 | 01:22 AM
paintballerr78's Avatar
Alright im going to be installing a turbo kit on my car
Its a 2010 ss/tc
Kit includes
Werks 5557 turbo
Werks turbo manifold
Dump tube
38mm Wastegate
Turbosmart mechanical boost controller
ZZP Intercooler
Dejon hotside cp
Question is what intake/lower cp and bov to buy. It does not come with these parts im having trouble debating which ones to buy. Also with the bov should i relocate the bov to the lower cp or no. Once i receive all the parts ill start a build thread with pictures.
Old Mar 9, 2011 | 12:00 PM
06ssTwinCharged's Avatar
Kit includes
Werks 5557 turbo
Dump tube
38mm Wastegate
Well you could just use your current intake for now and just keep the boost low because the plastic wont hold up to alot of pressure. I would say use ZZP charge tubes and intercooler
Cobalt & Ion ---> ZZ Performance
The intake I am running is one they also offer but the TTR intake is just a little more. I am pretty sure it would work with your car.
you might need a new down pipe also to bolt up to the turbo unless you have someone who can modify what you already have. My BOV is just off my intercooler on the CP. You might want to think of upgrading injectora also, I have a set of siemens 60lb and the harness with correct plugs for injector that I took off because I went up to 80s. I am currently making 461whp at 23psi. If you want injectors Ill sell injectors to you for 125 and 15 for harness
Old Mar 9, 2011 | 12:04 PM
TurboTechRacing's Avatar
Here is the intake manifold 06ssTwinCharged recommended:
Turbo Tech Racing Ecotec Intake Manifold - ON SALE! - Turbo Tech Racing, LLC
Old Mar 9, 2011 | 12:19 PM
Should of mentioned i have a 2010 ss/tc ahah
Old Mar 9, 2011 | 12:21 PM
Yeah this one wont work, but soon
Old Mar 9, 2011 | 12:33 PM
Ya basically need to find a intake to use idk if i want to use a whale ***** haha
LOL yeah then your intake would work great and you could upgrade later if you want its cast aluminum. ZZP does have a bad ass intercooler and charge pipe kit for the LNF also I plan on upgrading to that one when I am needing a little more power.
Old Mar 9, 2011 | 12:38 PM
ya i have hotside piping already and bought the zzp intercooler for 200 on black friday
Old Mar 9, 2011 | 01:26 PM
Ok sweet well if you want to upgrade injectors let me know, I got them from ZZP. I think you could probably get a good deal on the cold side CT from backyard turbo or ZZP. All my parts are from ZZP they have a really good 50mm BOV this is what mine sounds like
YouTube - 398whp Cobalt SS Twincharged
and here is an image with the BOV location on there CTs
http://www.zzperformance.com/products_img/1251_1.jpg
I will be getting my hands on there intercooler, CTs and there AFC (to boost MAF readings) this summer and hopefully hit over 500 at 23psi
Old Mar 9, 2011 | 01:33 PM
ya i dont need injectors cant upgrade them i have DI 2010 ss.tc
Supercharged06SS
Dec 11, 2022 04:47 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
maliki778
Oct 1, 2015 07:39 PM
