turbo HEEEEELLP
turbo HEEEEELLP
ok ima get my balt turboed but i need to know some things
1 where and how do I install the oil lines (and I have a auto trans)
2 where do i install the water lines from
3 do I need to do a swap on the injection system i know i have to maybe upgrade the fuel injectors but im talkin about the fuel system itself
4 i figure the saab 9-3 turbo mount would work but to what turbo
5 I was told a subaru wrx turbo would also work in my favor
if anything just please answer 1 and 2 and ill look else where if nobody would like to share the time and help
pictures are very welcome and would be a very good help of where id install the oil lines and water lines
well i know for mine, which is a 2.2 5-speed i got oil from the galley on the back of the block...i dont see why it would be different from yours, second the coolant came from the heater hose, i just made a t-fitting and a return line back to the overflow tank, 3rd, fuel system wise, you will be good wit 42s. on the 4th and 5th questions, i have no clue. the first 3 are wat i did for my turbo kit. good luck wit your build and be sure to keep us posted
